Eye of the Toiger
matty74's Avatar
thinking of ditching the 915 for a 930
because I'm committed to a turbo build on my 993 ( i really want to do it) I'm thinking of selling my 915 and just putting in a 930 tranny.
I don't want to have to comprimise on HP here or there and rather than killing a perfectly good box I'm thinking a 930 box. i don't want to do a g50 conversion and hack into my car.
anyone done this how hard is it what are the HP limitations of the 930 box.
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 03-07-2010, 08:12 PM
Turboo934's Avatar
You'll need a short 76-77 930 trans.
Robert. 1976 930/934 Turbo Carrera RRS, Cristine She can be evil but oooh so much fun
Old 03-08-2010, 01:02 AM
Eye of the Toiger
matty74's Avatar
I don't like my chances of finding one, any way to shorten them?
Old 03-08-2010, 01:11 AM
spence88mph's Avatar
patrick motorsports have a shortened g50 that goes in without torsion tube mods. That's what I would be gunning for...
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 03-08-2010, 03:51 AM
Smart quod bastardus
fredmeister's Avatar
does this require a conversion to hydraulic clutch though? What about the shift lever linkeage too.
The 4 speed box should be rated to handle large torque and hp so thats not a concern.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-08-2010, 06:23 AM
As mentioned Patrick Motorsports can shorten a 930 ( call and ask which year works best). I had one shortened. I thought it was a 1982 when I sent it ( the price is more if they have to take it apart but so would it cost more to ship if sent in complete ). It turned out to be a 1988 transaxle which is a little more difficult( more$$$) however the price was still around $1000. You will also need the transaxle cross member modified or just get a new one from Patrick MS and a different throwout bearing. Porsche rates the HP to around 700 so a good trans should do the job for most higher HP builds.
Anthony @ Voitureltd Bayside WI.
Old 03-08-2010, 07:05 AM
e p slick's Avatar
930 transmission
I have an excellent 1979 930 transmission for sale. Less than 2000 miles since rebuild. No gnashing/grinding/abuse.
EPS - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-08-2010, 08:30 AM
Are you going to be changing gear ratios?
If you do, and use aftermarket gears, be prepared for a fair amount of gear noise/whine.
T9
Old 03-08-2010, 08:36 AM
Eye of the Toiger
matty74's Avatar
My mate has a 930 box from a 78 which has a damaged bell housing, so I he said I can have it if I want, I just need a bell housing, do patrick sell for the 930?
is the internals the same for a 76-77 as is for a 78-89 box?
sticking with stock gears, don't mind the noise, I had a 4 speed 915 in my first car.
apart from side plate what can be done to toughen up the 930 even further?
Old 03-08-2010, 02:58 PM
Certified User
billjam's Avatar
Albins
Matt,
If you are considering changing gear ratios, talk to Albins in Ballarat. I fitted their close ratio gears for 2nd, 3rd and 4th and it totally transformed the car. Sacrificed a bit of highway economy and top speed, but well worth it, and not noisy. So much more fun to drive and by far the best bang for buck!
I wouldn't be surprised if they can also do the gearbox shortening mods.
Call them. Very helpful people.
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 03-08-2010, 08:37 PM
Eye of the Toiger
matty74's Avatar
Cheers for that Bill just sent them an email.
Matt
Old 03-08-2010, 09:02 PM
Eye of the Toiger
matty74's Avatar
Amyone know if i can mate a 76-77 belhousing with 79 guts?
whats mods are required to fit a 79 930 box to a 74 911?
Old 03-09-2010, 06:44 PM
Well for starters the input shaft is longer on a post 78 ( of course a 79 also) and can be machined to be the right length to match the shorter bellhousing of the pre 78 930 transaxle. I am not a expert so more may be involved. I defer to Patrick Motorsports of Phoenix AZ who does this as a business and will have all the answers. Also they do the conversions and/or offer the parts to fit the 930 trans into a 914.
Old 03-09-2010, 08:42 PM
What is the damage. Dose it have a limited slip.
It should be repairable and if you have it shortened it will take about an inch or so off the bell housing's length.
Old 03-10-2010, 08:23 AM
Infidel
JBL930's Avatar
I have a 4 speed from a 1987 930 with LSD. it was getting a little stiff into 2nd, and i think 3rd was starting to go too. So a few bits needed but otherwise it's a good box. I have all the 930 linkage and peddle box too, basically everything that would be removed from a 930 to fit a G50. I'm in the UK though so it may be prohibitive with carriage?
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 03-10-2010, 08:54 AM
