Boost gauge
My factory boost gauge works erratically and is seriously inaccurate even when it is working. My clock works fine so I am hesitant to replace it with a gauge. Where do you guys put the gauge if you don't put it in the clock space?
Old 03-08-2010, 04:18 PM
Drive it like u stole it.
jonesb930's Avatar
My clock was moved to the lower console. The PO made a new face that covered up the old tape holders. This allowed the 935 style gauge to be installed in the clock hole. It looked factory.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 03-08-2010, 06:31 PM
What about all the air conditioning controls?
Old 03-08-2010, 06:51 PM
jonesb930's Avatar
The two knobs for the AC are above the clock. The clock is below and centered, It looked good down there. Makes sense to have the boost gauge in easy view.
Bill Jones
Jupiter, FL
Old 03-08-2010, 06:55 PM
mark houghton's Avatar
Made a mount to replace the ashtray. Not in your direct line of sight, but then I don't look at it all the time. Just often enough to know that nothing has changed with boost and/or fuel ratios. Also made a covenient place to mount the remote radar detector.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 03-08-2010, 07:13 PM
Happiest when Tinkering
gsmith660's Avatar
Clock has never worked right so here is what I did
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 03-09-2010, 02:38 AM
1987 GP White 930
1977 Ford Bronco
Old 03-09-2010, 04:36 AM
Jones, do you have a picture of the set up? And willtel, are those factory gauges with red backgrounds and a space cut out for an electronic boost gauge or are they a whole new setup ?
Old 03-09-2010, 07:01 AM
jonesb930's Avatar
The car has been apart for about 10+ years so it is a bit rough. It looked MUCH nicer when it was a daily driver. The AC controls are removed but you can see the holes above the clock. The red LED was for the aftermarket alarm.
Bill Jones
Jupiter, FL
Old 03-09-2010, 06:12 PM
wjfk32's Avatar
Here is a 2 pics/my wrench's turbo...
The clock is placed perfectly/angle. No interference with a passenger/legs etc..
Old 03-10-2010, 06:30 AM
