9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
How much HP from 1 bar spring
Just curious, all things being equal,, with the only upgrade being a 1 bar spring. What would the increase in HP be ??
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 03-09-2010, 08:29 AM
Porsche-Poor
bcoats's Avatar
I've heard approx 20hp?
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 03-09-2010, 09:55 AM
Crotchety Old Bastard
RarlyL8's Avatar
It depends on the mods. If the engine doesn't flow well then less power.
I use 15HP/0.1bar as a conservative rule of thumb.
Old 03-09-2010, 09:58 AM
Metal Guru
911nut's Avatar
If you have a K27 I wouldn't bother going over .9 bar.
The factory only took the late model 3.3 turbo engine to .9 bar for a reason: 1 bar put the K27 over the choke line, so that really hot air was being fed to the engine.
I know this to be true because with my car the feeling of going between .8 and .9 bar is better than between .9 bar and 1 bar.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 03-09-2010, 12:49 PM
If you are going from a true .8 bar to 1 bar you can make up to 11% more power based on the math (.2/1.8=11%).
However, as others have noted there are things that will make it less as efficiencies fall off.
Old 03-09-2010, 08:53 PM
Not enough compare to the $s it might cost you, if that's all you do - just the spring.
Old 03-10-2010, 03:55 PM
