totle's Avatar
I can see that those adjustable timing gears are great for exact timing.
Old 03-11-2010, 04:30 AM
As to how much this effects power in the mid range I do not know for sure.
However, there was an PCA club racer that ran a 3.2 Carrrea and tested advancing his cams. Going from stock Carrera to a setting for more mid range added about 2-3% in the mid range. He felt it gave him an advantage over his competitors out of the corners and that is improved his lap times.
Old 03-11-2010, 07:19 AM
Originally Posted by totle View Post
Have been trying to set the timing today.
I was aiming for timing somewhere around 1.6.
It seems like I was only able to go with 1.4 or 1.7. Could not set timing between.
Am I doing something wrong or is this the case?
The setting in the wheel was only 1 hole to the side to get either 1.4 or 1.7.
Should I go with the 1.4 setting?
My goal is mostly street with some trackdays
I'm going to be doing this soon. Did you find a reason for only being able to set 1.4 or 1.7 or is that the only options? I want to get early power so I will be shooting for the 1.7 but I was hoping to learn all I could beforehand.
Old 04-28-2010, 11:19 AM
totle's Avatar
I ended up setting mine to 1,65
I struggled a bit to get right side equal to left.
Moving the pin 1 position gave me to big of a difference, so I ended up taking out the drive gear and turn it to another position in the chain and then try again until I had the correct setting.
Engine is going back in the car this weekend, so I am exiting to test out the performance :-)
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 04-28-2010, 11:54 AM
OK that make sense.
Good luck with the test.
Old 04-28-2010, 12:16 PM
