-   -   964 Intercooler Setup Help (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/531039-964-intercooler-setup-help.html)
28rusblue 03-13-2010 06:41 PM
Hi,
I recently purchased a 964 Intercooler for my 1978 Euro 930 to go with my RarlyL8 headers & exhaust, 1 bar spring, adj WUR, and K27S turbo.
Looking at the shipping tracking it will finally arrive from the USA in the next day or two.
I think the 964 intercooler I purchased also comes with the 964 pipe to the turbo, a 964 plastic BOV and the plastic pipe to the air box?
Unfortunately no mounting brackets or any other piping other than above comes with the Intercooler.
I was wondering if anyone had fitted one of these 964 Intercoolers before and how hard it was to fit to a CIS 930. What worked, what didn't, how you mounted it, and plumbed it up.
What other parts are needed from the 964 car's set up and what parts did you modify from your existing 930 setup? Will I get more HP from running the 964 plumbing setup or is the 930 plumbing set up better, or do I use a combination of both the two systems?
Does anyone have diagrams of the two systems?
What changes, modifications do you make to the way hoses and piping is run?
Any ideas and photos of how you fitted it up would be really appreciated.
Thanks,
Greg
RarlyL8 03-13-2010 07:11 PM
Take inventory of what you get with the intercooler when it arrives. There are several bits and parts. If something is missing we can help you out. Not a difficult swap.
28rusblue 03-13-2010 07:45 PM
Thanks Brian,
I'll post some photos when I finally get it.
Greg
cole930 03-14-2010 08:44 AM
Greg,
If you do a search here. Someone, kindly, posted a Kokeln install with pictures
and it's basically identical. It will show you how to replace the recirculation assembly and that would be were you're going to have most of the questions. Hope that helps and good luck. I do have that install info saved if you would want to send me an E-mail address.
Cole
JBL930 03-14-2010 09:55 AM
This was my 930 engine with a 964 intercooler fitted, not sure if the pics help
http://i139.photobucket.com/albums/q...bouttogoin.jpg
http://i139.photobucket.com/albums/q.../Enginepic.jpg
http://i139.photobucket.com/albums/q...epicforren.jpg
28rusblue 03-15-2010 12:01 PM
Thanks Cole and Jonathon
Cole, I sent you my email any info you have would be a great starting point.
Thanks for the pics, Jonathon, Can you remember what parts you used from the 964 and what you had to make up?
I'm about to pick it up this morning (snuck the morning off work). I will try to upload some photos of the parts that came with it.... I have just hope it survived the long journey o.k.
Greg
28rusblue 03-15-2010 02:51 PM
My 964 Intercooler pics
http://forums.pelicanparts.com/uploa...1268693195.jpg
http://forums.pelicanparts.com/uploa...1268693212.jpg
http://forums.pelicanparts.com/uploa...1268693227.jpg
http://forums.pelicanparts.com/uploa...1268693244.jpg
http://forums.pelicanparts.com/uploa...1268693262.jpg
http://forums.pelicanparts.com/uploa...1268693306.jpg
Here are the photos of what I have
What are all those outlets for? Looks rather complicated.
Any ideas and suggests on how to tackle and what else I need to buy would be much appreciated.
Greg
A930Rocket 03-15-2010 04:20 PM
I once had a 964 intercooler and bought the parts to install it. Ended up selling it for a Kokeln. :confused:
Anyway, here's a parts list I had:
http://forums.pelicanparts.com/uploa...1268698816.jpg
aerodyn930 03-15-2010 07:21 PM
Hello, Having done a couple of these installs, I would like to offer some info:
1- turbocharger to I/C inlet hose (very expensive , if yours is not serviceable a
replacement can be fabricated)
2-Coil bracket,( it has a different location for the I/C rear mount.
3-main I/C support mounts (they are mounted on intake manifold),
4-auxiliary air valve to I/C hose (different layout)
5-90 degree duct out of air flow meter with provision for recirculating(BOV) valve
6-Stock or aftermarket recirc. valve
7-Block off plate for Intake temp sensor
8-after removing your factory recirc. valve housing(if applicable) a connecting tube is needed between the 90 degree duct out of air flow meter to the metal duct going to turbocharger inlet.
as you know the A/C condenser has to be relocated out of the spoiler, also fabricate a restrictor baffle to promote airflow thru the I/C core.
as I am in the process of testing different I/C's will provide photos in a day or so.
If you need any of these parts fabricated, P. M. me
Regards , Lou
AERO DYNAMICS
28rusblue 03-16-2010 01:16 AM
Thanks Lou, Any photos would be great
elvision930 03-16-2010 09:45 AM
Sorry off topic. The picture with the intercooler on the engine. Your fan and fan housing look great. Did you polish it up or chrome it. Mine looks really oxidized and I want it to look like yours. Any ideas.
rsrfan 03-16-2010 10:05 AM
No. 1 above can be replaced with a 2" section of aliminum tube with an approximate 30 degree bend at the end, a 2 inch silicon "hump" hose and a 2"-3" silicon reducer.
No. 3 I used threaded heim joints and stainless tube in conjunction with small "L" brackets to attach the inetrcooler to manifold.
No. 8 I originally used a 3" aluminum tube with a 3" - 2.75: silicon reducer to connect to the factory air intake tube but have recently replaced with a custom 3" aluminum air intake tube with NO kinks.
Pics below
http://forums.pelicanparts.com/uploa...1268762623.jpg
http://forums.pelicanparts.com/uploa...1268762686.jpg
JBL930 03-16-2010 10:29 AM
I think it was lightly sprayed with some silver paint, didn't look like that for long! I would think powder coat would be best, but i have no idea if i'm honest
aerodyn930 03-16-2010 06:38 PM
Some photos of the parts: The two rear brackets are mounted on the manifold, the one with the long hexagonal body substitutes one of the nuts on the manifold for cyl #4, the other mounts on a threaded hole next to the rubber mount for the a/f meter. The photo of the coil bracket shows the different layout, finally the shot of the recirc. valve mounted on the 90 degree duct out of the A/F meter,
The plumbing, Drivers side: 1-waste gate
2-Deccel. valve(if not on your car, plug nipple)
3-Recirc. valve
Pass. side 1-aux air valve
regards, Louhttp://forums.pelicanparts.com/uploa...1268793213.jpg
http://forums.pelicanparts.com/uploa...1268793283.jpg
http://forums.pelicanparts.com/uploa...1268793388.jpg
28rusblue 03-19-2010 07:33 PM
Sorry for the slow reply but go called out of town for work on short notice...as usual
Thanks Lou
And Thanks everyone for your pics and help.
I'm just starting to get my head around it. But sorry in advance for all the questions. especially for the dumb ones...lol
I need the below list of bits? Anything else you can think of?
1. BOV Boost hose (93011038200)
2. 964 BOV (got one)
3. 90 deg rubber elbow (between turbo to intercooler pipe) 93011025900
4. 1 X Aircooler support (93011022302)
5. 2x Air cooler Support Bracket Rubbers
Can anyone tell me what part number that coil bracket Lou posted is?
After I remove the recirculation assembly what do I need to connect the 964 intercooler to the inlet body
In the photo of Jonathons 964 what are the senders fixed to the intercooler and do I need to buy theses bits?
On my 964 intercooler what hoses get connected to outlets A B C D E ?
Greg
ZLP 03-19-2010 07:37 PM
I have a new in box 965 intercooler shroud (the one that attaches to the top of the intercooler). Let me know if you are looking for one.
28rusblue 03-19-2010 07:47 PM
Would anyone know this bits part number?
http://forums.pelicanparts.com/uploa...1269056463.jpg
What gets connected to these outlets A B C D E?
Do I need to buy any sensors?
http://forums.pelicanparts.com/uploa...1269056683.jpg
Do I use this pipe?
http://forums.pelicanparts.com/uploa...1269056743.jpg
28rusblue 03-19-2010 07:55 PM
David also sent me some good photos of a prepared engine bay
After I remove the Recirculation assembly what do I need to connect to the inlet?
http://forums.pelicanparts.com/uploa...1269057115.jpg
How do I and what do I need to connect to the inlet in the center of the photo?
http://forums.pelicanparts.com/uploa...1269057226.jpg
Thanks for all your help
Greg
A930Rocket 03-20-2010 03:09 AM
^^^ The intercooler will sit on the throttle body above. The various mounts will hold it down.
IIRC, you can use the existing o-ring but order a few extra as they can tear.
28rusblue 03-21-2010 12:04 AM
Thanks A930Rocket, that gives me one end all sorted out. I'll get a few spare o rings.
I think I'm starting to get my head around some of it now.
Thanks,
Greg
cole930 03-21-2010 06:42 AM
Greg,
The bracket your loking for: 930-110-224-02
http://forums.pelicanparts.com/uploa...1269181446.jpg
If your car is a 930 you already have it. It sits on the left side of the round cooling fan housing that the cooling fan runs in and the coil is bolted to it. Look at the balck ignition coil in the next picture the coil is bolted onto that bracket.
http://forums.pelicanparts.com/uploa...1269181838.jpg
Here is how the rubber elbow and the Bov connect to the fuel distributor and then the spacer then the down pipe to the turbo.
http://forums.pelicanparts.com/uploa...BOV+Piping.jpg
http://forums.pelicanparts.com/uploa...1269182362.jpg
I don't know what else I can offer from here !!!! Good Luck !!!!
Cole
cole930 03-21-2010 06:51 AM
Greg,
Here is another pic of the plumbing from the side that show all the connections:
http://forums.pelicanparts.com/uploa...1269183020.jpg
Cole
28rusblue 03-22-2010 03:39 AM
Thanks David,
Now I think I'm right, I guess I have just got to make a start.
This is my first project solo on my car and I think I'm a little hesitant in case I hurt it.
Need to :rolleyes: and just get into it...
Time to order the bits and do it.
Thanks again for your help,
Greg
911st 03-22-2010 08:42 PM
The turbo inlet pipe you showed is from a 930 and dose not need the C2 Turbo elbow. You could order all the tubing from the metering assembly to the turbo and it might make a small improvement in air flow as it is a better design. You need the elbow out of the metering box anyway to fit the newer style BOV.
You can use any tubing option to connect the turbo outlet with the intercooler but the factory rubber hose is a better design and can make for a small decrease in pressure drop. It is graduated and has reliefs built in at each end so the internal transitions are smother and to minimize disturbance of air flows. Probably not noticeable but that is its reason for being.
28rusblue 03-26-2010 01:45 AM
Thanks 911,
I order some bits from our host but they will take over 12-15 days to get here (frustrating). I will try to post some photos as I fit the intercooler and ask for different ideas on best way to hook up the hoses...Just a little scared I'll blow it up or damage something.
Thanks to everyone for all the help as soon as the bits get here I'll have a go....
Cheers,
Greg
RarlyL8 03-26-2010 04:10 AM
Greg, what parts are you missing? Did you source the factory up-hose?
I have misc bits and parts, let me know what you still lack.
28rusblue 03-26-2010 01:53 PM
Thanks Brian,
I think I have everything apart from the 3in to 2in tapered rubber Intercooler hose. I refuse to pay $361 for foot long rubber hose.
If anyone has any ideas on fabricating one let me know. I was going to try to use a 2in to 3in exhaust reducer or try to modify my existing 930 pipe.
If anyone has one sitting around.... let me know.
Cheers,
Greg
RarlyL8 03-26-2010 07:09 PM
I think I still have this 964T part. I'll dig it out for you. If interested shoot me an email, I'll sell it for what I paid a few years ago.
http://forums.pelicanparts.com/uploa...1269659325.jpg
28rusblue 03-26-2010 11:40 PM
I've sent you a email
Greg
ertech 03-27-2010 04:17 AM
got a khol;en reucer part pm me if iterested
911st 03-27-2010 07:59 AM
I hope Brian can help you with that tube.
That tube along with the intercooler's end tank designs are probably the best design of any 930 IC system and should help to keep pressure drop at about the lowest of any system.
I am a big, big fan of the C2 Turbo intercooler set up.
28rusblue 03-27-2010 05:17 PM
Yes, I hope Brian can find his one.
$361 us dollars is pretty steep when converted into Australian dollars and then adding the shipping costs to over here...
But, the factory hose must be tapered for a good reason.
I've heard the C2 is a really good unit. I think someone did some testing on temps and acceleration on here recently and the C2 performed really well when compared with some of the aftermarket units.
I think It should go well with one of Brian's K27S turbos and his exhaust & headers which were fitted to my car last week...made a big difference to my car, can hardly wait to get the K27S turbo on and this intercooler sorted out.
RarlyL8 03-27-2010 09:03 PM
Yes I found it and it is put aside for you. Your turbo and BOV shipped on the 26th so the tube missed that boat. Shoot me an email if you need it shipped now. Shouldn't be too bad as it weighs maybe a pound. Your cams should arrive any time so we can ship them together if not urgently needed.
28rusblue 03-27-2010 10:27 PM
Thanks Brian,
That's great news I new you would find it, so I PayPal you some money earlier today.
May as well wait for the cams to turn up and ship it with them.
I'm waiting for some other bits to be shipped by our host and looks like a hold up from Porsche's end anyway.
forwheeler 04-02-2010 06:27 AM
Do I use this pipe?
Small hijack...
I just got a blown six 964 intercooler so I am figuring out what to connect where. Mine has the holes for the pipe fittings but no fittings so I can connect hoses. Is it typical for to need to weld in your own? Where do I get the fittings to weld in? I looked at the usual sites including ebay but I'm not sure what they are called so it is hard to search for them.
28rusblue 04-04-2010 01:32 AM
Hi Forwheeler,
Not sure if this is what your meaning... but if you have threaded holes in your Blown 6 cooler, you should be able to find alum or brass air-hose barbed ended fittings with threads that suit. As an ex-carpenter, try any place that sells a range of nailguns and nailgun nails as they will usually have a complete range of air hose fittings, all sorts of brass hose joiners and thread sealer usually at a reasonable price.
Or if you have no threads in the holes maybe very carefully tap a thread that suits standard airhose fittings. But make sure you get all those metal scraps and filings out of that intercooler.... wouldn't want them to go through your engine.
Greg
forwheeler 04-05-2010 04:17 AM
Originally Posted by 28rusblue (Post 5275602)
Hi Forwheeler,
Greg
I can find some fittings for the threaded holes like you said. I was hoping to find some place which sells press in or weld in fittings for the unthreaded holes. I can try to buy a couple large taps, 1" and 3/4" I think to thread them. I was more curious if the intercoolers come without threaded holes for some reason. Thanks.
