-   -   AFR gauge mount (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/531400-afr-gauge-mount.html)
930lad 03-16-2010 05:43 AM
AFR gauge mount
any one care to share where they have mounted their AFR gauges. I want to keep my clock.....saw Stup mount his in his ashtray assembly....pics maybe?
jwasbury 03-16-2010 07:10 AM
http://forums.pelicanparts.com/uploa...1268748542.jpg
I bought the gauge panel from Summit racing...its an Autometer brand. Pelican sells a VDO gauge panel too that would work fine. I tried to buy it from our host but the part was on backorder for weeks.
mark houghton 03-16-2010 08:18 AM
This was kicked around just recently. Go here http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/530103-boost-gauge.html
billjam 03-16-2010 08:32 AM
I fitted my Innovate G5 gauge into a PVC pipe connector covered with vinyl and screwed to the underside of the dash. Wires run through clock hole.
Pics worth a thousand words ...
http://forums.pelicanparts.com/uploa...1268753352.jpg http://forums.pelicanparts.com/uploa...1268753371.jpg
http://forums.pelicanparts.com/uploa...1268753386.jpg http://forums.pelicanparts.com/uploa...1268753400.jpg
http://forums.pelicanparts.com/uploa...1268753413.jpg
john930 03-16-2010 01:38 PM
This where I attached mine, these gauges are quite thin and can be surface mounted.
http://forums.pelicanparts.com/uploa...1268771819.jpg
JBL930 03-16-2010 02:38 PM
I like this, it's right there in your face, which is where you want it!
930lad 03-16-2010 03:07 PM
many thanks fellas....i just needed to see what you guys had done....much obliged.
cole930 03-16-2010 06:55 PM
Display is tied to onboard Innovate LM-1
Colehttp://forums.pelicanparts.com/uploa...1268790928.jpg
Dave 86 930 Fl 03-17-2010 04:21 PM
I removed my radio and used some black Starboard which has a pebble finish that is similar to the leather on the dash ... I'm happy with the placement, as it's out of my primary view.http://forums.pelicanparts.com/uploa...1268868077.jpg
mark houghton 03-17-2010 07:42 PM
Old One,
That gauge looks like a dead ringer for the old DynaTune unit I used to have installed and hooked to my narrow band stock location O2 sensor. It read in millivolts and you had to have pre-programmed into your brain the conversion chart to AFR's. Worked in a pinch to signal danger zones, but that's about it. Still have it, need to sell it to some non-discriminating buyer.
And something about age and vision accuity....either I'm loosing my eyesight, your camera is out of focus, or you're loosing your eyesight. Or a combination of all of the above.
Yours Truely,
Mr. Gimp
cole930 03-18-2010 07:11 AM
Gimpy,
It is a Dyna Tune, conversion done in LM-1 lots of help on the Innovate Forum with the conversion charts.
You need to cut me some slack on the vision, I just turned 67 yesterday and my eyes were the second thing to go. Looks fine to me !!!!
I actually didn't have time to do another pic. and download. I also knew some
smart ass from the Great NW would be pimping me for sure.
Cole
mark houghton 03-18-2010 09:37 AM
Originally Posted by cole930 (Post 5243140)
Gimpy,
Cole
Never wanting to be the source of disappointment, as always I aim to please!
Happy belated birthday, by the way. Hope you have many many more to come.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
