930lad's Avatar
AFR gauge mount
any one care to share where they have mounted their AFR gauges. I want to keep my clock.....saw Stup mount his in his ashtray assembly....pics maybe?
1988 930, (modified )
Old 03-16-2010, 05:43 AM
beancounter
jwasbury's Avatar
I bought the gauge panel from Summit racing...its an Autometer brand. Pelican sells a VDO gauge panel too that would work fine. I tried to buy it from our host but the part was on backorder for weeks.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 03-16-2010, 07:10 AM
mark houghton's Avatar
This was kicked around just recently. Go here Boost gauge
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 03-16-2010, 08:18 AM
Certified User
billjam's Avatar
I fitted my Innovate G5 gauge into a PVC pipe connector covered with vinyl and screwed to the underside of the dash. Wires run through clock hole.
Pics worth a thousand words ...
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 03-16-2010, 08:32 AM
This where I attached mine, these gauges are quite thin and can be surface mounted.
Old 03-16-2010, 01:38 PM
Infidel
JBL930's Avatar
I like this, it's right there in your face, which is where you want it!
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 03-16-2010, 02:38 PM
930lad's Avatar
many thanks fellas....i just needed to see what you guys had done....much obliged.
Old 03-16-2010, 03:07 PM
Display is tied to onboard Innovate LM-1
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 03-16-2010, 06:55 PM
River Rat
Dave 86 930 Fl's Avatar
I removed my radio and used some black Starboard which has a pebble finish that is similar to the leather on the dash ... I'm happy with the placement, as it's out of my primary view.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 03-17-2010, 04:21 PM
Cole
Old One,
That gauge looks like a dead ringer for the old DynaTune unit I used to have installed and hooked to my narrow band stock location O2 sensor. It read in millivolts and you had to have pre-programmed into your brain the conversion chart to AFR's. Worked in a pinch to signal danger zones, but that's about it. Still have it, need to sell it to some non-discriminating buyer.
And something about age and vision accuity....either I'm loosing my eyesight, your camera is out of focus, or you're loosing your eyesight. Or a combination of all of the above.
Yours Truely,
Mr. Gimp
Old 03-17-2010, 07:42 PM
Gimpy,
It is a Dyna Tune, conversion done in LM-1 lots of help on the Innovate Forum with the conversion charts.
You need to cut me some slack on the vision, I just turned 67 yesterday and my eyes were the second thing to go. Looks fine to me !!!!
I actually didn't have time to do another pic. and download. I also knew some
smart ass from the Great NW would be pimping me for sure.
Cole
Old 03-18-2010, 07:11 AM
Gimpy,
Cole
Never wanting to be the source of disappointment, as always I aim to please!
Happy belated birthday, by the way. Hope you have many many more to come.
Old 03-18-2010, 09:37 AM
