Eye of the Toiger
matty74's Avatar
will a GSF 1.65 OD headers fit a 3.6
Is a 1.65 primary too restrictive on a 3.6 turbo? I know that GSF headers are not as good as others etc.. but I am restricted by budget and can get a set locally, cheap.
I was planning on buying a K27s or HF from Brain, so I'd look at getting a set of Brians headers down track.
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 03-16-2010, 04:25 PM
E-85 sippin drunk
turbobrat930's Avatar
That is what I am running on mine.. (Just got the set from Brian)... Remember, these are turbo engines... yes they need to breathe, but we also have to keep exhaust velocity up. Personally, I would not go any bigger....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-16-2010, 08:00 PM
Crotchety Old Bastard
RarlyL8's Avatar
Primary/secondary optimum size depends on a lot of things. Most importantly how much air will blow through the engine; boost level, redline RPM and anticipated HP at xRPM. Displacement is much less a factor than these others.
You need to match your exhaust port size so if you use the GSF take the time to cone the gasket protectors so you have smooth transition from the heads to the primaries.
Old 03-16-2010, 09:03 PM
Some GSFs don't fit regardless...
Old 03-17-2010, 06:16 AM
Porsche-Poor
bcoats's Avatar
Is GSF still in business? That guy scammed me. . .
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 03-17-2010, 12:36 PM
It is to seriously address this issue. Quality above than the price.
Old 03-17-2010, 01:01 PM
Eye of the Toiger
matty74's Avatar
I'm talking (1.625") OD. It seems a little small for 993 heads. If I go the stock 993 headers and M&K Y pipe I need 2 waste gates, what waste gates do you guys use? Stock or can I use a pair of Tial WG
Old 03-17-2010, 03:36 PM
RarlyL8's Avatar
I use 38mm TiAL on all my dual wastegate setups.
Old 03-17-2010, 08:04 PM
Eye of the Toiger
matty74's Avatar
Is 1.625 OD so 38mm ID too restrictive on a 3.6 turbo?
Old 03-17-2010, 09:10 PM
RarlyL8's Avatar
Depending on the build, 1.625" may be too large. Your boost level, amount of air blown through the engine (turbo and porting), redline, xHP @ xRPM goals all affect design for maximum exhaust velocity without choking the engine. With your large heads you would want to open up the gasket protectors and flange area for a smooth transition.
Old 03-18-2010, 05:13 AM
