R.I.P.
drmatera's Avatar
i raised required fuel by 25% which richens the whole VE table by that amount. I am running 60# injectors that can support the power numbers i'm making... And I totally understand that e85 power peaks at a different "lambda" than gasoline. But since Lambda is lambda is lambda how can it get skewed the farther off stoich I go?
A = 1
Z = 26
if I say B or 2 it means the same thing regardless of the fact that the digit has a different shape. I'm not sure this can be explained anymore than it has been. lambda numbers are what they are PERIOD . The gauge could display the word boobies when at .8 and dog when at 1.0 That doesn't change the fact that it's still the lambda reading
Old 03-19-2010, 07:40 AM
Crotchety Old Bastard
RarlyL8's Avatar
It should display dog at cruise and boobies at 1.0bar. I think that is the problem.
Old 03-19-2010, 09:52 AM
Large Member
krasuskyp's Avatar
Oh snap - WHERE do I score me on of *those*??? BRIAN GET ON IT!
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 03-19-2010, 10:06 AM
R.I.P.
drmatera's Avatar
bbrbrbrbrrrrrrrrrumsky
Old 03-19-2010, 12:52 PM
R.I.P.
drmatera's Avatar
while i could stare at those fun bags all night here is my dyno sheet
Old 03-19-2010, 04:30 PM
Rocket Scientist
Displacement = 3.3L or 0.0033 cubic meters
Lambda 1 = 9.8 A/F
RPM = 5500
Boost = 1.2 Bar or 221 KPA absolute manifold pressure
Inlet Man temp = 35 C (just a guess, but typical) or 273 + 35 = 308 K
Gas Constant = 0.287 KJ/Kg*K
Mass of air = [(221)(0.0033)]/[(0.287)*(308)] = 0.00825 Kg of air for every 2 revs
(0.00825/2)*5500 = 22.7 kg/min or 1361 kg/hr or 3000 lb/hr of air
3000/9.8 = 306 lb/hr of fuel
306/6 = 51 lb/hr of fuel per injector
You are running way over 20% rich so you need at least 20% more fuel: 1.2 * 51 = 61.2 lb/hr
But you have 60 lb/hr injectors, so you're done.
You can go back to staring at pictures of boobs now.
Old 03-19-2010, 06:17 PM
R.I.P.
drmatera's Avatar
yes, at 10.5 a/f (7.0 lambda) I saw 104% duty cycle on my injectors. I am aware that the 60's are done
BTW, my peak inlet temp was 115*F
Old 03-20-2010, 09:21 AM
Rocket Scientist
Airflow = 3000 lb/hr
Boost = 1.2 bar (120 kPa)
3000/2.2 = 1364 Kg/hr
Volume flow = [(1364)(.287)(293)]/98.1 = 1169 m3/hr or 1169/3600 = 0.32 m3/sec
Pratio = (101 + 120)/101 = 2.19
Plot that on the map below. You are in no man's land. No wonder your intake temps were so warm, only 60% compressor efficiency. You should go up one turbine housing size also (no map for that unfortunately). You need bigger injectors and a bigger turbo. Things are adding up fast! I hope you do it though. E85 is a great answer for a turbo motor. Watch out for the Bosch fuel pumps (if that is what you are using). I think some of them use a white plastic around the motor armature the disolves when exposed to alcohol over time.
Old 03-21-2010, 11:47 AM
Smart quod bastardus
fredmeister's Avatar
what turbo was this compressor map from thats posted?
do you have one for the k27S turbo that you could send me or post it?
this is very valuable info.
thanks,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-22-2010, 04:36 AM
R.I.P.
drmatera's Avatar
wow, she is off the map. I ran it at the drag strip sunday. She went 12.75 @ 117.75mph at a race weight of 3190 (with me). The boost would slowly decrease as rpm climbed so I turned up the boost controller to try and compensate. At the top of the rpm range the boost always ended up around 16.5-17psi. My lambda was still around 7.0-7.3 all the way down the track (i added a few pounds of fuel pressure) and she ran like a champ.
speedy squirrel- thanks for all your technical input, i'm a simple guy, my knowledge of performance turbocharging is from the school of hard knocks... it's interesting to see the math behind it all.
Yes, i'm still on the stock fuel system. I'm watching carefully as the the bosch pumps don't like alcohol. I had a bosch 044 on my turbocharged mustang and it ran on E85 for 3 years. But when i broke the transmission the car sat for over a year. When it ran again the bosch was dead.
Old 03-22-2010, 07:43 AM
Rocket Scientist
5327 988 7200
930.123.013.04
aka the "K27 7200"
[QUOTEdo you have one for the k27S turbo that you could send me or post it?
this is very valuable info.[/QUOTE]
No, I only know the Porsche part number at this time (930.123.003.03). I need the cross-reference number (5327 XXX XXXX) to come up with the correct compressor map. Do you have it? I suspect it is the same compressor though.
Old 03-22-2010, 05:38 PM
E-85 sippin drunk
turbobrat930's Avatar
Holy cow!!! 104%??? duty cycle... WOW
I was thinking of running 85 or 100lb injectors in mine when I run E-85. This is what I wanted to talk to you about over the phone. I think max we should be at 80% duty cycle. The bigger you go though, the idle will get harder to tune in.....
On a related note, I have a friend with a twin turbo big block producing over 2500 HP in a four door AMC Rambler.... he is using E-85... and loves the stuff!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-22-2010, 05:59 PM
Turbofrog
smurfbus's Avatar
If you're going to swap for bigger injectors you should consider the Bosch EV14 injectors. Nice numbers on the strip.
Old 03-22-2010, 11:06 PM
R.I.P.
drmatera's Avatar
turbobrat - yeah we need to get in touch but i've been so busy with work I don't seem to have a moment to think during the week.
I've got a set of 80Lb injectors here i'm going to try. They can function at a lower duty cycle than the 60's so i may get an improvement in idle quality
Old 03-23-2010, 08:08 AM
R.I.P.
drmatera's Avatar
New update.....................
new dyno numbers with billet wheel S262
1.3 bar
450.3 rwhp / 436 rwtq
I'll post graph tomorrow
Old 08-11-2011, 04:37 PM
1.3 bar
Nice numbers! Dynojet, Mustang or? What level of octane?
Old 08-11-2011, 05:57 PM
R.I.P.
drmatera's Avatar
It's a dynapac dyno and the car is running E85
Old 08-11-2011, 06:35 PM
TurboKraft's Avatar
Well that works!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 08-29-2011, 09:32 PM
you feel comfortable running 1.3bar (18.8 PSI) on your stock internal engine? I know your fuel and spark is modern, but I thought the issue with higher boost is hitting cyl pressure limits? I'm not sure where to top off my boost, currently I have ob fuel cut at 1 bar. Nice numbers by the way!
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071
Old 08-30-2011, 01:59 AM
Turbofrog
smurfbus's Avatar
Time to hit the strip again or are they closed now?
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 08-30-2011, 02:49 AM
