Crotchety Old Bastard
RarlyL8's Avatar
RarlyL8 Skunkwerks - for those who like it LOUD
I've had a few requests to produce this item pictured but questioned how many might be interested in such a thing. Well I have sold enough mufflers (thank you all and Pelican!) to offer this not only as a stand alone but as an optional long-tube zork to all those who currently have one of my mufflers.
It is a simple muffler bypass; a tube instead of a muffler. Simply take the muffler apart and slide this puppy on. You want a GT3 Zork? No problem. Dual out Zork? Can do. Stock outlet Zork? Only you and the entire neighborhood will know. Can also go out the passenger side if that floats your boat. Makes for a cool 934 look as well with the matching waste gate pipe. Big 'n little flames.
I do have to figure out how to secure the assembly but that shouldn't be a problem.
Old 03-18-2010, 07:29 PM
At a future time, I think I would like to try a dual out without a muffler. I was surprised at how tame the sound of your dual outlets are with the muffler. My Powerhaus seemed louder. The Borla, I just did not like. I would expect the price would be similar to what I paid for the present dual out I am running?
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 03-19-2010, 12:02 AM
Eye of the Toiger
matty74's Avatar
that is awesome how do they sound
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 03-19-2010, 01:14 AM
C'mon Stuart, my dual out 4.5" B&B exhaust is fine. I just haven't heard it in 14 months. She comes alive again next week! Loud pipes saves lives.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 03-19-2010, 01:31 AM
RarlyL8's Avatar
You can use the bypass pipe with my second generation (modular) muffler so cost is reasonable. I'm hoping to be able to knock off $100 on the complete assemblies that have the bypass pipe in place of the muffler body. It gives folks more choices when it comes to sound level.
Loud!
... but not quite as loud as the short tube zork, as expected. The idea is to give you the a cheap/easy option to run Hooligan on the weekends or at the track. This pipe can be changed out in 15 minutes with the car on the ground and the valance in place. Remove my muffler, bolt up the bypass to the turbo, pop on the U-pipe and tailpipes, clamp it down and go. You can also pop the muffler back on when driving on tracks where you fail the sound restrictions. The pipe is small enough to toss in the trunk and weighs ~3 pounds.
Old 03-19-2010, 06:37 AM
Large Member
krasuskyp's Avatar
Akila-
I'm highly considering taking off my year-old dual out / snub WG, and swapping in a pass side exit zork / driver side exit WG.
Maybe we could work something out.
Brian, let us know when you have a la carte pricing worked out 8-). I'm in no hurry, car's still of the road for the season - sigh.
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 03-19-2010, 08:00 AM
onboost's Avatar
Pricing on this one?
Thx
RGruppe #180
Old 03-19-2010, 08:22 AM
RarlyL8's Avatar
For now just knock $100 off the price of any muffler that has the bipass pipe in place of the muffler body. I just need to cover costs on this one. Buying a compelete system with a bypass pipe instead of a muffler seems very pricy as you are left with just tubes but those tubes are expensive. The entire system will weigh less than 10 pounds. You can also add a muffler body at a later date if desired.
Old 03-19-2010, 08:53 AM
krasuskyp
I would be up for it. Let me know.
Hey Bryan O, why is the 91' not in your sig.? Bout time that 86' is finally gonna hit the road.
88' 930
Old 03-19-2010, 09:41 AM
After the next project
x98boardwell's Avatar
Question
Brian,
What is the difference between the larger unit that is packed and the thinner one that is not packed.
I loved how my car sounded when I first received the unit from you... but shortly thereafter the packing burned away in the muffler now it is louder than ever... too loud for my taste. Is this normal and expected? I love the fit, look and finish of the exhaust but was curious as to options?
My thought is that the larger unit with the packing burned away will be almost (very close) as loud as the just the straight tube. Am I correct in this assumption?
Thoughts?
Thanks,
Bryan
Previous cars:
2007 GT3, 2006 Cayenne TTS, 1991 928 S4, 1987 930, 1975 914 2.0, 1989 944 Turbo S, 1991 964 Targa, 1991 964 Convert, 2004 996TT Convertible, 550-6 Spyder with a 2.4 liter twin plug "S-spec'd motor"
Current cars: 2012 Cayenne TT, 1997 993TT, 1984 Jeep Grand Wagoneer, 94' 928 GTS, VW GTI
Old 03-19-2010, 10:23 AM
Large Member
krasuskyp's Avatar
krasuskyp
Uh oh - d'oh - Brian... looks like my inquiry to you on 'this' has been expedited 8-).
Can you pls pm or email me what just the pass side out straight thru bit / driver side out WG dump would be?
TIA!
past:
Old 03-19-2010, 10:58 AM
RarlyL8's Avatar
Gorgeous car!
The sound deadening material is not supposed to burn out, if it has and you don't like the sound send me the muffler body back and I'll send you a new one.
No the can with no sound deadening material is not as loud as the straight pipe. What you (now) have is the Hooligan version of my muffler. It is a perforated expansion chamber, about 1/3 the sound level of a Zork. On a scale from 1-10 with stock being a 1, the street muffler is a 3 the Hooligan a 5 the bypass 8 and Zork a 10. Harley's are off the chart.
Old 03-19-2010, 11:03 AM
krasuskyp
It lives in Florida now.
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 03-19-2010, 11:30 AM
Rarlyl8
Brian,
I sent you a PM.
Thanks,
Bryan
Previous cars:
Old 03-19-2010, 01:17 PM
How many Bryans/Brians are on this forum? lol
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 03-19-2010, 03:49 PM
RarlyL8's Avatar
Fortunately this Brian B spells his name with an "i" or we'd really be confused.
Old 03-19-2010, 06:54 PM
Brian,
Does anyone in Honolulu have your turbo exhaust as I'd like to hear one in person. How is it compared to the B&B 4.5" dual out?
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 03-19-2010, 07:15 PM
RarlyL8's Avatar
Yes, there are a couple in HI, I'll have to dig up the email addresses. If memory serves one of the fellows replaced a B&B with my dual outlet.
Old 03-19-2010, 08:43 PM
Brian, any progress w/the modular heater boxes for your headers?
Old 03-21-2010, 05:34 PM
RarlyL8's Avatar
I'm hoping they will be laser cut this week. Unfortunately they are not a priority at the machine shop, VERY frustrating.
Old 03-21-2010, 09:45 PM
