Chain fence eating turbo
Protomotive tuned factory ECU using 380cc injectors on an '87 C3.2 with 427 whp here. I would go through a tank of gas in about 3-4 days with a round trip of 50 miles a day all highway (was a DD for a couple of months).
Not so great....
Never could calculate actual numbers due to odometer being broke.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-20-2010, 06:45 PM
Weight and drag seem to be the two most significant parts of fuel economy.
CIS and EFI can both be tuned to run near peak efficiency but it is much easier to achieve a near ideal AFR and ignition settings with EFI.
After that it seems to be about increasing the VE of our motors at off WOT settings.
Off boost compression (up to +10%) and exhaust efficiency seem to be the next variables in line. Twin plugging probably being close behind (up to +4%).
One is going to make more power out of the same amount of fuel with more compression and get more from each gallon.
Reduced back pressure reduces drag on a motor during the exhaust stroke for more power from each gallon.
Twin plugging allows for later ignition during the compression cycle for less resistance being created before TDC and more power from each gallon.
Of course, a motor that puts out 500hp is going to use +/- 100% more fuel at WOT than one making 250hp.
With a CIS 930 the biggest challenge is achieving significantly more timing advance at part load cruse to get the most out of every gallon of fuel. Most run about 25 deg advance on curse. Most modern cars run well into the 30's of advance on curse.
Thus, I suspect our most significant limitations are frontal area, compression ratio, and the stock 930's timing system.
Old 03-22-2010, 10:42 PM
