-   -   Where to get C2 elbow or alternative (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/532617-where-get-c2-elbow-alternative.html)
forwheeler 03-22-2010 05:49 PM
Our host seems to sell these but it is a special order. Anyone know of an alternative elbow? I assume that I can get a silicone albow and then attach a BOV to the IC correct?
aerodyn930 03-22-2010 06:21 PM
Here are photos of two alternatives for plumbing the BOV discharge into the turbo inlet ducting, one photo shows a factory elbow modified with a 1" aluminum flange and a short connector hose (places the valve in the stock C-2 turbo location), The other photo shows a steel 1" elbow bolted to the connector tube between the A/F meter elbow and the turbo inlet steel duct, Both work equally well.
Regards, Louhttp://forums.pelicanparts.com/uploa...1269307076.jpg
http://forums.pelicanparts.com/uploa...1269307190.jpg
turbobrat930 03-22-2010 06:42 PM
If you contact Kokeln directly, they sell an installation kit which inlcudes the 90* rubber elbow, the Al connection pipe, and the recirc valve.....
forwheeler 03-22-2010 07:25 PM
How does the 1" aluminum flange mount to the elbow in the first picture? I assume this is a custom piece and it is inserted from the inside of the elbow.
mark houghton 03-22-2010 07:31 PM
An elbow just sold on eBay for $30. I almost picked it up, just because, but I already figured out an alternate way to do the updated BOV without it.
A930Rocket 03-22-2010 08:06 PM
Doesn't the factory elbow go from say 4" to 3" and then the aluminum adapter takes it from 3" to 2 1/2" (or some similar numbers?).
You could probably get a 90* silicone elbow and have a muffler shop make a reducer for you. No idea if this is cost effective.
forwheeler 03-22-2010 08:32 PM
Maybe I could use a straight metal pipe and use a reducer piece like this.
SR-250-300-BK
Falk930 03-24-2010 12:08 AM
I have build this a while ago, machined from alumiunium.
It fits straight on the 930 elbows, bov can be connected easy.
http://www.alumex.de/930/Saugrr.jpg
Falk
forwheeler 03-24-2010 04:15 AM
Falk
It looks like it has a step in the pipe instead of a taper. Does that cause problems with the air flow? It has nice machining.
Falk930 03-25-2010 10:22 AM
forwheeler, the aluminum piece is optimized for flow.
There is no step inside, its a cone ( hopefully my english fits here ~)
More, on the bigger side the edge was cutted with a nice radius.
For flow, the part is fine, much better then the 930 original piece.
Falk
forwheeler 03-25-2010 10:40 AM
Ah yes, very nice!
