Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
WTB: Air Injection Plugs
Lost an air injection plug this past weekend after several years. Made the car sound like a 67 VW Bug.
Anyway, I did a search on the issue and a competitor of out host has them in ST ST from Weltmeister for $39 I think it is. I need ONE. Looking on-line, I can't find it in the pitch I need (M10x1.0), nor can I find them locally. Even McMaster-Carr didn't have them
Anybody know where I can ONE? Or maybe two and I'll have a backup?
Old 03-23-2010, 08:35 AM
A930Rocket's Avatar
Nobody?
What about a M10x1.0 allen bolt in ST ST?
Old 03-23-2010, 01:46 PM
They are used commonly in hydraulics (port plug).....try your local hydraulic/hose fitting service
DIN 908 M10x1.0 port plug
Old 03-23-2010, 01:54 PM
A930Rocket's Avatar
Thanks! I'll give it a try.
Old 03-23-2010, 04:49 PM
E-85 sippin drunk
turbobrat930's Avatar
I need four of them. How about you buy the package of 6 and I will buy the 4 off of you..... No rush on getting them to me as I have SEVERAL more months before mine is running....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-23-2010, 04:51 PM
LSR911
injection plugs
Mercedes drain plugs work. Go to a local MB shop or dealer. As I remember it is a transmission plug. Has a nice flange and uses a hex wrench for installation. Use a copper ring seal and they don't fall out.
Old 03-23-2010, 06:16 PM
Wo ist die Rennstrecke?
DonE's Avatar
I have 5 you can have. Two are hex barrels and three are the MB drain plugs. One is lost - that's why I welded the holes closed and did away with these things.
Old 03-23-2010, 06:33 PM
Non User
infraredcalvin's Avatar
you need to verify this, but it's my understandng that the same plug is used on the 914 rear caliper part number PEL-BRC-02 from our host. they are $2.95 each...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'74 914 track basket-case
Old 03-23-2010, 08:38 PM
Turbofrog
smurfbus's Avatar
Could this hole be used as an exhaust pressure measuring point? Or EGT?
Old 03-23-2010, 09:18 PM
TurboKraft's Avatar
Thumbs up
I think we can help you out if still in need.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 03-24-2010, 10:23 AM
A930Rocket's Avatar
Thanks guys. Went to my local hyd shop and picked up 2 for $3.50 each.
Old 03-24-2010, 11:26 AM
Smart quod bastardus
fredmeister's Avatar
As a point of reference I found that 1/8-NPT pipe plugs have almost an identical pitch thread and will work up in there. However, from thermal expansion and a tapered thread this is not the ideal solution (and may eventually work loose) but will work in a pinch, like at the track!
914 brake caliper plugs are the same part. Can you get a set of those? =========PEL-BRC-02
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-24-2010, 12:44 PM
