Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
SEE YA's Avatar
Oil Pressure on 930 were should it be at?.
Hello, all when running on idle what should the gauge say inside the car is it up near the 4/5 area on the dash. Also when you are driving the car what should it be as well please?.
Thank you all for your time and help.
911/930 turbo 87
Old 03-25-2010, 06:53 AM
elvision930
elvision930's Avatar
Hmmm. Mine is lower at idle. 2/3. That is the druck press gauge. It makes sense that it should be. I would think. Ah...then when you open it up or hit boost the pressure should go up. 4/5. mine just spikes there momentarily then drops down when I slow down. I think this is normal. No expert though.
Check out this link below. I googled it and it seems on par. This gentlemen had his druck press drop. Normal freeway speeds it read 5 dropped to 3.5.
question about oil pressure drop.
Old 03-25-2010, 07:39 AM
Richard930's Avatar
Depends on the engine mileage, oil type etc. I use 20W50 dyno oil in my car with 250,000km (150,000 miles) on it (no rebuild). Pressure at cold startup idle is about 3-4 bar, warm idle is about 1 bar, fully warmed up the oil pressure is about 1+ bar per 1000 rpm (3 bar at 2,200 4 bar at 3,000 rpm +). From what I understand warm idle pressure is not too important and on a hot day with moderately high engine temps it may show just below 1 bar - enough to cause the warning light to flicker on occasionally, but as long as the pressure follows the 1 bar per 1,000 rpm rule of thumb then there's nothing to worry about. You need to get very worried and shut down immediately if there is a sudden pressure drop and the red idiot light comes on.
When these engines were new the pressure was probably pegged at 5 bar on cold start and anything above 2,000 rpm, but as the engine wears the pressure will gradually reduce.
Last edited by Richard930; 03-25-2010 at 10:52 AM.. Reason: Clarify running pressure
Old 03-25-2010, 10:50 AM
At idle, after warm up, it should be 1 bar and 1 bar/1k rpms after that. At 5k rpms it should at 5bars or close to. If the car is hot, at idle it could be a tad below 1.
Old 03-25-2010, 03:06 PM
