tuning ? what order
when adjusting C0% , timing and idle whats the rule of thumb on the order?
Timing, CO then idle
Ditto.
Timing must be set at a fixed number nomatter what. Adjust idle to keep the engine running. CO% must be set in a fixed range at specific timing. Adjust idle to keep the engine running. Idle must be adjusted to ~1000rpm at specific timing and CO% depending on what engine/smog equipment you have. |
Thank you kindly!
| All times are GMT -8. The time now is 01:17 AM. |
