Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Remove AAV and cap manifold
I want to remove the AAV and need to plug the manifold fitting. The hose is 3/4" on the AAV side and 1" at the manifold. How did you plug the manifold? I can use a short piece of 1" hose and put a bolt in it but there must be a cleaner way of doing this. I purchased a 3/4" cap for the intercooler side but I can find a 1" cap.
Old 04-08-2010, 04:09 AM
Boost Abuser
LOWFAT's Avatar
I found a cap at Napa. I have heard of some people using a short piece of hose with a wooden dowel rod cut to fit and shoved in the hose.Seems to work as they had no problems since the install.Hope this helps.
Old 04-08-2010, 07:03 AM
sudo apt-get purge 930
equality72521's Avatar
Most auto parts stores sell rubber caps.
--clutch-monkey
Old 04-08-2010, 07:38 AM
mark houghton's Avatar
I'm always too lazy to run down to the auto store for a more ellegant fix, so I opted for the short piece of hose plugged with a bolt and hose clamp.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 04-08-2010, 07:41 AM
you can go to the hardware store or home depot and buy a similar rubber thing for the end of a chair leg that will fit too.
it might even last a few years.
Old 04-08-2010, 07:56 AM
JFairman, the chair leg cap is a good idea.
I went to 2 auto part stores already and they only had caps to 3/4" and I need a 1" cap.
Old 04-08-2010, 09:37 AM
Beware of cheap rubber caps, they usually dry rot within the first year and the end blows out. They have no reinforcing like a good piece of hose.
A bolt or dowel in a piece of high quality hose is ugly as can be, but usually works well over time.
My 2 cents.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3 w/MS3X, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 04-08-2010, 10:05 AM
winrice is right . it just happend to me last week/
Old 04-08-2010, 11:35 AM
I ended up using a wood dowel and hose to cap it off.
Thanks for the help.
Old 04-09-2010, 06:38 AM
Crotchety Old Bastard
RarlyL8's Avatar
I use reinforced rubber hose with steel pipe caps and a clamp. Looks OK and functions long term.
Old 04-09-2010, 08:57 AM
