-   -   I need help bad! 3.3 won't run at all. (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/535871-i-need-help-bad-3-3-wont-run-all.html)
mark houghton 04-09-2010 03:39 PM
Originally Posted by Wolf300tt (Post 5286422)
I guess the inside of a wur is not supposed to look like this.http://forums.pelicanparts.com/uploa...1270851912.jpg
I love a good AHHH HAAA! moment......
Still, your system pressure should not be as high as it is. Correct me if I'm wrong, but the WUR has nothing to do with system pressure....only control pressure. Probably should pull out that pressure regulator from the fuel head. I would bet it looks similar to your WUR.
JFairman 04-09-2010 04:00 PM
Wow. . .
and yes the WUR has nothing to do with system pressure.
I hope the system pressure regulator in your fuel head doesn't look anything like that... don't see how it could since fuel is constantly flowing through it while the motor is running and the corroded parts of your WUR are vented to atmosphere.
Maybe the vent hose on the top has been missing on yours and when the car was washed or when it rained water got in there... and stayed there eating the insides.
Wolf300tt 04-09-2010 05:27 PM
I'll tear the regulator down tomorrow. As for now, I need to find a replacement WUR.
JFairman 04-09-2010 05:36 PM
The WUR vent line origonally went to the bottom of the air cleaner housing, (your origonal uneditted post came into my email) and it takes about 10 seconds to unscrew and remove the system fuel pressure regulator so get an early start... :)
good luck with it.
mooney265 04-09-2010 05:50 PM
Wow! When was the last time you drove anywhere in this car with that WUR?
BTW: I don't have an extra... I do know there are different model number ones but don't know the differences between them...
A930Rocket 04-09-2010 05:52 PM
What about Brian L? Might as well get one of his modded ones while your at it.
Wolf300tt 04-09-2010 06:58 PM
Brian L.?
mooney265 04-09-2010 07:04 PM
Adjustable 930 WUR Website
email him. i've got one - - it works great!!
Wolf300tt 04-15-2010 07:05 PM
New WUR...new life. Also found hidden air leak at the AAV.
2450 pounds of scary fastness!
Thanks to all who felt compelled! You guys rock!
Drew
A930Rocket 04-15-2010 07:24 PM
Good news wolf!
WinRice 04-16-2010 08:08 AM
Nice!
And nice looking car!
Are you running a WBO2 gauge? With that single pump, you need to make sure you have enough fuel on top so you don't run lean.
BTW, here's the specs I have for the 1986 US 930/68 3.3L engine, your 1987 should be the same or close to it:
System Pressure
Test Value 6.7-7.4 bar (yes, the later lambda cars run more system pressure, early cars run 6.0-6.7 bar)
Adjusting value 6.9-7.1 bar
Control pressure warm 3.75 plus/minus 0.20 bar
Full Throttle Enrishment 2.90 plus/minus 0.20 bar
I have the temp graph I can PDF if you need it.
Wolf300tt 04-18-2010 05:52 PM
I am actually just beyond the "get it running" stage. I will be getting in deeper in the coming weeks.
Again, thanks for all the support and compliments.
Drew
JBL930 04-19-2010 12:11 AM
Did you throw that old WUR in the bin? You should have sentit to Brian Leask as mentioned above, he would have cleaned and rebuilt it and made it adjustable. How much did you pay for a replacement one?
Wolf300tt 04-19-2010 06:17 AM
I kept the old wur with sending it to Brian Leask in mind. I don't need an adjustable wur yet, but in the future it could come in handy. I bought a good used one for $200.00.
Drew
JBL930 04-19-2010 07:44 AM
That's a good price for a used one Drew, you got a good deal there!
In my opinion the WUR should have been adjustable from the factory, everyone should have it done, every engine runs slightly different, and people live in different climates, it allows you to fine tune the fuel to suit your car, which is a great idea regardless of whether it's stock or not.
A good condition stock one will be fine though, especaially when you got it so cheap, might be an idea to pop it open just to check the condition of the diaphragm, they obviously deteriorate with age so it's worth a look. And for the sake of stating the obvious make sure you connect that vent on the top back to the airbox.
h20cooled7 04-20-2010 05:07 PM
If this helps, I had a similar problem and this is what I found. My main wiring harness was cooked and melted the cold start injector circuit and the warmup regulator circuit and the fuel cutoff on the fuel meter. I Repaired harness and reset fuel mixture and routed the harness so it wasnt pinched and the issues went away. Just wanted to throw it out there.
