Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
beancounter
jwasbury's Avatar
Electromotive XDI2 - help please
Gents.
Trying to fire up my rebuilt engine for the 1st time. According to the manual, the bottom LED is supposed to flash during cranking. If no flashing, the XDI isn't seeing the crank sensor. I have no flash. Checked sensor with VOM and its 620 exactly as its supposed to be. Verified sensor wiring.
Still no flashing LED.
Any ideas.
Old 04-10-2010, 10:49 AM
what? me worry?
TimT's Avatar
Double check the air-gap between the sensor and the toothed wheel. The electromotive sensor is kind of a pos....it is a proximity sensor used on industrial type equipment.. i.e. conveyors etc..
Have seen a number of sensors just go bad..
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 04-10-2010, 12:09 PM
They have a new 3/8 sensor that is quite robust. The old ones had some problems. If you have the new, thinner sensor, they have to be lined up with the chisel point on the sensor face on exactly the 11th tooth. Also check the weather pack connectors. Sometimes when you push those in, they push the other prong out thus breaching the connection. Did you use two relays to juice both units? If so, there could be a problem with the pin layout with those. Also make sure the main grounds are secure on the block. Once you get it dialed-in, very trouble free with amazing tune-ability.
Old 04-10-2010, 12:24 PM
Have also had a sensor go bad, stops you in your tracks. I suggest you carry a spare just in case.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 04-10-2010, 12:36 PM
beancounter
jwasbury's Avatar
I'm an idiot
The switched 12v source I was using to trigger my relay did not continue to get 12v with the key in the start position. DUH! Car fired right up.
Unfortunately its making an ugly noise, I think from the valve train. Ugh.
Old 04-10-2010, 03:40 PM
Oh no. Take a deep breath and approach it with a clear head, if you are a drinking man now is the time to have a stiff one.
1987 GP White 930
1977 Ford Bronco
Old 04-10-2010, 04:56 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Jacob, glad you got it started and I hope you find the problem. It could be a loose rocker or rocker shaft. I had a few loosen up quickly after 200-300 miles. Noise and leaking oil like a sieve.
Old 04-10-2010, 07:05 PM
