79-930
Help; Sachs Pressure Plate Removal
I'm installing a new clutch and pressure plate assembly on a '79 930. I've removed the starter ring completely but am unable to remove the old Sachs pressure plate.
Do I have to just pry it off or are their any special tool requirements?
Old 04-12-2010, 03:56 PM
You may need to tap it lightly around the circumference to break it loose. It should come right off now that all the bolts are out.
Emery
1988 930 coupe - Silver Metallic
3.3L w/GT35R, B&B Headers, RarlyL8 muffler, TurboKraft IC, Tial WG, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 04-12-2010, 04:51 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Or you may need to tap on it hard if it's really stuck.
Old 04-12-2010, 05:09 PM
79-930
Thanks for the advice. If you look very closely at the picture the 2nd hole diameter from the left side of the photo you will see a faint white line; it's a crack.
I'm removing the 4 speed for a full rebuild; 1st & 2nd gear synchros are just about gone and this is what I also find.
Old 04-12-2010, 05:17 PM
