Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
David's Avatar
Air Fuel Ratio chart
Thought some of you guys could use this:
From the Motec site:
peak power at Lambda between 0.84 and 0.90 (non-turbo obviously)
best economy at Lambda equal to 1.05
optimal emissions at Lambda slightly lower than 1
2014 Cayman S
2011 Cayenne Turbo
Old 04-20-2010, 05:31 AM
So with a low boost aplication (on a 3.0 SC) I would want the ration to be between 12.5 and 13.2? Is this on boost or through out the RPM range?
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!----
-1978 911 SC TURBO, Minerva Blue Targa 965 update.
-2008 550i M-Sport
Old 04-20-2010, 01:10 PM
David's Avatar
That's just on boost. Since it's air-cooled, I'd go 11.8 at full boost to be safe.
2014 Cayman S
2011 Cayenne Turbo
Old 04-20-2010, 01:29 PM
Metal Guru
911nut's Avatar
We all run rich because we assume that air flow is not equal to all cylinders.
If we were building race engines that had to develop max power with the highest possible economy, we'd flow the intake and heads until everything was near equal and run an afr of 12 - 12.5 because that's where max torque is made, regardless of whether the engine is turbocharged or not.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 04-20-2010, 03:18 PM
89 930.
Benny771's Avatar
Whats the "easiest" way to check this?
Some type of analyzer i can buy?
Old 04-20-2010, 03:40 PM
David's Avatar
The easiest is to take it to a tuner shop and have them put it on a dyno with a lambda sensor in the exhaust pipe.
There are stand alone lambda sensors you can install. I think they're anywhere from $400 to $2000.
2014 Cayman S
2011 Cayenne Turbo
Old 04-20-2010, 03:53 PM
89 930.
Benny771's Avatar
What about those tail pipe sniffer thingies?
Old 04-20-2010, 03:59 PM
Champagne on Beer Budget
HelmetHead's Avatar
Why Yes Thank You....I do need this! Lambda sensor came in today!
Einar
87 911 Turbo
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 04-20-2010, 04:04 PM
Here is a Co to AFR chart: The MG & MGB Experience: Library: CO% to Air Fuel Ratio (AFR) Table
I believe max TQ is at about 13/1 to 13.2/1 for a normally aspirated 911 motor. I have seen a turbo at 13/1 but that takes a lot of heat management and race fuel.
Many tuned performance turbos run in the 12.2/1 range that have more accurate fueling and adaptive systems to protect the motor.
Many turbo cars that come from the factory like WRX's will often run in the mid 10's in stock form on boost. My guess is to protect the motor from detonation.
I believe we tend to want to run in the mid 11's at TQ peak where risk of detonation is highest.
Not an exert on this, just what I believe so far.
Old 04-20-2010, 04:08 PM
Using the Co chart, setting idle CO at 3.5% gets us a 13.2 AFR and should achieve the best pre-boost performance. Stock Co gets us around a 14/1 AFR which is better for idle and cruse AFR.
Unfortunately the 3.3 930's do not have acceleration enrichment,just boost enrichment, so it comes to a decision between performance or efficient cruse MPG. The 3.0 Turbos did have acceleration enrichment with loss of manifold vacuum.
Getting a more ideal pre boost AFR and ignition advance can noticeably improve off idle performance.
Old 04-20-2010, 04:17 PM
David's Avatar
Tuning drive tomorrow evening?
2014 Cayman S
2011 Cayenne Turbo
Old 04-20-2010, 04:24 PM
HelmetHead's Avatar
Perhaps later in the evening...I got the Kiddo solo tomorrow.
Einar
87 911 Turbo
Old 04-20-2010, 04:43 PM
Richard930's Avatar
Benny771 - where are you located? I've got an Innovate LM-2 AFR meter on order and will be willing to 'consult' with it, for a small fee of course!
Richard
1982 930, K27-7200, Ruf wheels, Leask WUR, Tial WG, WEGO IV AFR, RarlyL8 headers & single out muffler, TK I/C
2011 R350 winter beater
2004 BMW R1100S
Old 04-21-2010, 07:15 AM
check out the Daytona Sensors Wego IV. Pelican now sells them. I have one and it is a great AFR unit with data logging.
73 Carrera RS spec 2.7 MFI
03 Saab 95 Aero
01 Saab 95 Aero
90 Chevy PU Prerunner....1995
RGruppe #79
Old 04-23-2010, 09:35 PM
