Twinreds's Avatar
Exclamation Motor mounts
Any recommendations on motor mounts? I'm considering WEVO's. Are they good?
Any other players?
Thank you
Old 04-21-2010, 03:20 AM
I used WEVO on my 911 and they worked fine. Pelican also has some of their own polyurethane mounts - cost less and should be less rubbery than stock. I am about to install them on my 930 - not sure if they will be too harsh or just right...
Emery
1988 930 coupe - Silver Metallic
3.3L w/GT35R, B&B Headers, RarlyL8 muffler, TurboKraft IC, Tial WG, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 04-21-2010, 05:46 AM
sudo apt-get purge 930
equality72521's Avatar
What is the real advantage in using harder mounts? What are the disadvantages?
--clutch-monkey
Old 04-21-2010, 06:38 AM
Hirevtuner's Avatar
With hard mounts you have less deflection. I used solid motor and trans mounts.
Felt more vibration and then my trans cross member pulled out and dropped. I believe related to the mounts. Now I use Wevo semi solid motor mounts and stock trans with no problems.
1981 411 rwhp, Ruf intercooler, 964 cams, Turbo Kraft injector blocks, Extrude honed intake, 7006 Turbo, Tial wastegate, RarlyL8 exhaust, MSD6al
Old 04-21-2010, 08:48 AM
David's Avatar
Wevo in back and stock up front. So far no problems and I don't notice vibration coming through.
Wevo can install their mounts on the tranny if you want, but you have send them the 930 mount.
2014 Cayman S
2011 Cayenne Turbo
Old 04-21-2010, 11:57 AM
Wevo blues in the back with stock up front, like David.
Maybe a very slight increase in vibration, but a pretty big difference in shifter feel. You don't get the weird pops and movement that feels like the engine is rolling around when you shift under boost.
I have the Wevo blue DIY kit for the front, just haven't installed it yet.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 04-21-2010, 01:20 PM
Wevo blues front and back. Makes everything tight and steady with little to no vibration, noise issues.
Old 04-21-2010, 04:32 PM
steven c's Avatar
Porsche 3.8RS engine mounts on mine, stock up front. No vibes.
91 964 turbo
63 SWC Vette Race Car since 1966
69 Vette Race Car since 1971
07 Z06 DD
Old 04-22-2010, 06:13 AM
gumba's Avatar
I use Wevo blues in back and front. I would go with the blacks which are a little softer. Wevo can modify the trans mount and install the mounts.
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 04-22-2010, 08:38 AM
Twinreds's Avatar
Exclamation
I will be going WEVO blue in back and stock in front.
I will post feedback.
Thank you all for the help.
Miguel
Old 04-22-2010, 09:47 AM
Don't you risk damage to the engine since it is absorbing what the mounts were designed to do?
--clutch-monkey
Old 04-22-2010, 02:15 PM
