Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Protomotive Instructions??
Does anyone have instructions from Protomotive for a 3.2 conversion? Looking for a "check list" for my conversion.
thanks,
Ben
1986 3.2 Carrera
Old 04-24-2010, 04:22 PM
Nashville84Cab's Avatar
Ben,
Here is another link that might help you (thanks to charlesbahn for posting):
Protomotive Stage ! Install (Part 1)
Do a search and you will find a number of posts that will help you. I would recommend reading and learning as much as possible before buying anything (don't need to reinvent the wheel). Make a plan on what your goals and budget (don't forget to include AFR meter and boost gauge). And if you are going with stock compression, don't boost over .7 Bar!
Good luck!
Darrell
Darrell
1984 3.2 Carrera Turbo Cab - Protomotive chip, B&B Headers, M&K Exhaust, Garrett GT30, Tial WG (46mm), Custom Intercooler, "Big Reds" 993TT brakes, In-Your-Face Gauge Boost/AFR Gauge, and Removable Hardtop
Old 04-27-2010, 08:47 PM
spence88mph's Avatar
+1 I used the same instructions a few years ago, are you using a Protomotive FPR? They really make life easy instead of an adjustable but either way it's a pretty easy. Took me 2 afternoons and I took my time. What turbo are you using?
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 04-28-2010, 03:18 PM
