vmb vmb is offline
vmb's Avatar
Buckley rear sway bar mount?
I was looking for the WEVO mounts and saw the Buckley racing mounts listed right after the WEVOs here on Pelican. Am I reading it right that they weld right over the OEM mounts? That seems to be a lot easier than cutting/grinding off the old mounts. Anyone use them here? I picked up a 22mm rear bar at Hershey last weekend and don't want to run into a failure w/ the stock mounts.
Vic
1979 930 with Rebel coilovers and many more parts on shelf to be installed.........
Honda Odyssey minivan parked under the turbo
former Tony//Kart shifterkart owner
Old 04-29-2010, 11:53 AM
vmb vmb is offline
vmb's Avatar
Never mind. Done with work, able to google more and found the answer. Still need to cut off the old mounts: Buckley Racing - Installation Instructions
Vic
Old 04-29-2010, 01:26 PM
cl8ton's Avatar
Vic don't forget you have the rear fuel cage in the way on the rear drivers side to deal with when welding in new mounts.
The Buckley instructions gloss over this fact.
Here is a thread I started that deals with this issue.
TRG swaybars & Wevo RARB mounts
Good Luck!
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 04-29-2010, 05:08 PM
