Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Camshaft oil line restrictor update
Anybody using these? Did you notice a bump in the oil pressure? Any problems?
Old 05-03-2010, 06:32 AM
one of the great unwashed
patkeefe's Avatar
I had them for a while. Yes, you get a bump in oil pressure. I removed the restrictors because I didn't like the looks of the cam wear. There is a big discussion on these if you search the 911 technical forum.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 05-03-2010, 07:25 AM
Thanks for sharing your experience. After reading the other thread I probably won't be installing them.
Old 05-03-2010, 08:11 AM
Wo ist die Rennstrecke?
DonE's Avatar
It's a horrible idea to restrict oil to the cam lobes for the sake of increased oil pressure. Especially when you can shim the oil pressure relief valves safely and achieve the same thing.
Old 05-04-2010, 05:10 PM
MikeD930's Avatar
Agree! I drilled larger holes in the oil line restrictors on my '91/92 engine for this reason. The original holes were small! Luckily my cams and rockers are fine.
MikeD
'87 930
Old 05-04-2010, 07:14 PM
3 restos WIP = psycho
kenikh's Avatar
This mod is OK-ish for folks with sissy oil pumps, like early cars, but personally never use it. With a 930/GT3 oil pump, there is no reason to use it, especially with today's crap oil.
I have seen a few folks actually take the restricted ones and ream them to a diameter half between stock and the small hole, which seems to work well as a happy medium.
Bottom line, though...no car with a turbo pump should run this mod.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-05-2010, 07:53 AM
