built4sound's Avatar
catch basin/ scavenge pump question
Ok, I'm working on getting oil out of my old Rayjay turbo as fast as possible. I have just dramatically upgraded the size of my drain line out of the turbo, but due to how low it is mounted I'm very skeptical of my gravity drain into the chain cover.
If I were to add a scavenge pump after a small basin after the turbo, should I put a vent in the basin to prevent the pump from pulling oil out of the turbo when I am really just using it to force the oil to its destination.
Also while we are talking about it, any advice on what to use for a pump or basin. Any advice would be great.... It's time to get back on the road without blowing clouds of smoke!
74 911s
2.7 Turbo
Old 05-07-2010, 09:59 PM
Happiest when Tinkering
gsmith660's Avatar
Post a pic I have a factory drip can and an electric scavenge pump that I can let go if intrested if it will fit your turbo.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 05-08-2010, 05:33 AM
here is what the setup looks like on the car, not detailing the drain because it will change.
74 911s
2.7 Turbo
Old 05-08-2010, 06:01 AM
gsmith660's Avatar
Thats the old BAE setup isn't it? good starting point what boost are you going to run? I am running .5 bar and seems to be holding up fine on my 2.7
Old 05-08-2010, 06:33 AM
Yes it did start with an old BAE set-up. Realy only used the upper piping and the turbo, the rest was custom done.
You definitly took the project pretty far, thats a great looking set up on your car.
74 911s
2.7 Turbo
Old 05-08-2010, 07:04 AM
gsmith660's Avatar
Thanks it has a 3.2 intake, EFI, EDIS ignition, MSDS intercooler, Euro exhaust, Tial wastegate all a test bed for a 3.2 SS build later down the road.
Old 05-08-2010, 10:25 AM
