EmptyGarage's Avatar
Help in removing bearing dust cover
Hi,
I washed car and it must have took a while to dry especially the brake rotors. When I went to move car front pad had bonded to rotor. Once it free itself the brakes started to grab. When I inspected the rotors is see that a small amount of brake pad material is bonded to rotor. it needs to come off!
I'm stuck with HOW to remove front bearing dust cover. One in picture. While I'm looking at rotor how do I adjust the from bearings as they have a little play?
thanks
for the help!
Old 05-10-2010, 12:57 PM
Blaine Sellie's Avatar
I have removed the dust covers before by threading a bolt in to the cap and using a slide hammer....it popped right out. Any chance you could just remove the material that bonded to the rotor by sanding disk or??
B
1988 Porsche 930 Factory Slantnose
2011 Porsche Panamera Twin Turbo
1974 Porsche 914 2.0 Phoenix Red
1965 Shelby Cobra Replica- 428FE
Old 05-10-2010, 01:15 PM
Oh Haha's Avatar
I replied in the 911 Tech section as well. The 911s do not have this front hub cover. Ours are generally pryed off withi various methods.
Front Wheel Bearing Replacing Instructions
Pacific Blue
Wayne
Old 05-10-2010, 01:42 PM
You can see in picture that I already unbolted hub from rotor so it's to late to do anything while still on car. I'll need to remove to hold bolts to re-attach hub and rotor.
What about adjusting the wheel bearing any suggestions.
Thanks for the link to the other thread....Back out to garage to get this thing moving.
Old 05-10-2010, 01:44 PM
Oh Haha's Avatar
more info on adjusting the bearings here-http://forums.pelicanparts.com/porsche-911-technical-forum/354848-front-wheel-bearings.html
Pacific Blue
Wayne
Old 05-10-2010, 01:53 PM
Oh Haha's Avatar
more info on adjusting the bearings here-//forums.pelicanparts.com/porsche-911-technical-forum/354848-front-wheel-bearings.html
Pacific Blue
Wayne
Old 05-10-2010, 01:54 PM
Non User
infraredcalvin's Avatar
Check this thread:
Front rotor question
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 05-10-2010, 08:43 PM
Rocket Scientist
Slide hammer is the official. Works most of the time. A LITTLE heat on the hub doesn't hurt.
Old 05-10-2010, 10:46 PM
cycling has-been
bkreigsr's Avatar
I've been using a pair of BF ChannelLocks to remove any caps that I have not had off before. Choose a channel that gets the handles very close together and rock it up and down until you see some movement. If the hub were still on the car, I'd suggest rotating the hub 90 degrees at a time and rocking until you see some movement.
I've had the center threaded bung strip out several times.
oh, and a couple of 130-0 panic stops should remove any built-up lining material.
Bill K
Old 05-11-2010, 05:07 AM
Rocket Scientist
I am going to try that next time. I actually had the threaded part pull off one time.
Old 05-11-2010, 09:44 AM
Champagne on Beer Budget
HelmetHead's Avatar
I used my harmonic balancer puller tool backwards and threaded the correct diameter bolt through the center puller bolt hole with a second backup nut on a washer to create the pull...worked perfectly
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 05-11-2010, 12:09 PM
Did not have correct tread bolt to tread into dust cover...so I re-attached the hub to rotor and then just cleaned the rotor in-place.
I will need to tackle this again to adjust bearing but I'll find the correct bolt to use to extract this. I have one that was very close, but not exact...metric system...
Old 05-11-2010, 03:49 PM
