Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
spark plugs
hello all; I am about to install a MSD 6AL and was wanted to know which spark plugs would be best for this application, and also if anyone has experience with which gap is best. thanks Philip
87 930 GHL/Rarlyl8 dual/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LC-1/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin plug coil packs/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo install in progress. 500+ HP, BTSOMP Dyno
Old 05-11-2010, 02:45 PM
wjfk32's Avatar
You will get alot of opinions. It was alot of trial and error with me. My car has cams, polished heads, 7006, no cat, bb dual exhaust...etc..etc. Certain plugs work for some setups and others don't run as well. Inmop denso w24esr-u pregapped .032 works for me. I want a plug for top end. 90% hwy driving for me. The only thing I don't like is the warm up time in cold weather. It takes me approx 2-3 times to turnover in cold weather.
Walt
Old 05-11-2010, 03:37 PM
I have the same ignition and I use Bosch W4CS and gapped them at .040"
They are silver tipped plugs.
Works perfect here in Florida year round and probably would in Canada too.
Old 05-11-2010, 05:33 PM
mark houghton's Avatar
I gap .040 as well, with NGK racing plugs, R5671A8. Always had good luck with NGK in other applications, and anything with the word "race" next to it just turns me on. Ran with 7 heat range for a spell, but thought they were just a little too hot.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 05-11-2010, 07:41 PM
