Wastegate Mystery
I noticed on my 3 liter Turbo the wastegate has a bolt on the top in center. Should that be the vent or is it different on the 3 liter cars? The other port near the bottom is connected as it should.
Old 05-12-2010, 10:41 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I gotta think it should be like a 3.3 and vented. But what's keeping it from overboosting? Wouldn't a bolt in there do that?
Old 05-13-2010, 02:34 AM
I was thinking the same that a bolt would create more boost not being able to release pressure. Just want to make sure what stock is and put it back if needed.
Old 05-13-2010, 02:41 PM
mark houghton's Avatar
Yep, it needs to be able to vent at the top of the housing or the diaphram won't move in response to boost pressure. If I recall, my stock WG had a banjo and hollow bolt up top and a steel line leading to nowhere. If your WG is working ok, then maybe you've got a banjo with the end cut off to allow it to vent? Just a thought...
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 05-13-2010, 04:25 PM
Old 05-13-2010, 04:58 PM
PM sent.
Old 05-13-2010, 05:57 PM
89 930.
Benny771's Avatar
According to some friends who use to race these. People would put a reg. long bolt in there and when they wanted more boost they would simply turn the bolt.
I have also seen one that had a flex cable welded to the bolt and run into the car to a adj. knob.
Easy boost controller.
I don't believe it is crucial that the top "breathes" There is not much top pressure in these (travel is quite small).
Old 05-14-2010, 08:24 AM
Good point Benny...having the top closed to atmospheric pressure may not have a big impact since the travel distance is so small.
As far as the bolt used to adjust spring tension on top, that has been discussed quite a bit over the years. Would have to spend some time searching threads to understand the pros and cons.
Old 05-14-2010, 10:13 AM
