Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
air filter replacement
pretty basic question but if there is a trick i don't know about... i want to replace the air filter in the stock air box. do i need to loosen / slide the a/c compressor out of the way to get the clearance needed once the bottom of the air box is cracked open?
Charles
79 930 #632
88 911 Cab
74 TR6
88 CRX Si
Old 05-16-2010, 01:01 PM
After the next project
x98boardwell's Avatar
Answer
I have an A/C equipped 87-930 and have always been able to just crack the air box on the front, open it up as much as possible (an inch or slightly more) and slide the air filter out bending it slightly to get it past the A/C unit. I have never had to mess with the A/C for the air filter. I do have a K&N air filter... not sure if that would make a difference. It doesn't seem like it would.
Hope this helps,
Bryan
Previous cars:
1987 930, 1975 914 2.0, 1989 944 Turbo S, 1991 964 Targa, 2004 996TT Convertible, 550-6 Spyder with a 2.4 liter twin plug "S-spec'd motor"
Current cars: 2006 Cayenne TTS, 1991 964 Cabrio, 1997 993TT, 1984 Jeep Grand Wagoneer
Old 05-16-2010, 02:26 PM
E-85 sippin drunk
turbobrat930's Avatar
Also I have a K&N air filter for sale that has never been used for a 930... if you are interested....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-35RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 05-16-2010, 02:45 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Stock or K&N, you have to work at getting it in. A little KY would help.
J/K....
Old 05-16-2010, 06:06 PM
Driver
Noah930's Avatar
Having just replaced the air filter on my stock engined car last month, no, nothing has to be disassembled. Flip the three snaps, slide the old one out, slip the new one in, lock the snaps.
1987 Venetian Blue (really looks like grey) 930 Coupe
Old 05-17-2010, 08:55 PM
mjmoran's Avatar
I usually just use this time to remove the Intercooler and AC pump. The box is much easier to get at and you can inspect and clean items which normally are impossible to get to. 15-20 min of removing items allows for much better access and a lower possibility to loosing or breaking something.
JMHO
Michael
PCA-INWR
356 Reg.
Early S Reg.
R Gruppe PNW
Old 05-22-2010, 12:07 PM
