Throw Out Bearing Install Help
Guys what is the trick to installing the TOB through the pressure plate? BTW, Its a 77 930.
Old 05-17-2010, 05:27 PM
I just did this... No trick. Place the throw-out bearing in from the inside, the fit is really loose. When you tighten the pressure plate onto the trans, the "fingers" tighten around it. Thats it...
The 930 throwout bearing is totally different than what Wayne's book and the other manuals show...
Old 05-17-2010, 05:39 PM
Notice the clip (one of three) around the edge of the pressure plate. Did you remove these prior to install? I believes these are making the opening tight so you cant just slide the TOB through.
Old 05-17-2010, 06:15 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Yes, remove the clips. As you tighten the PP down, it will close the spring fingers arounf the TOB.
Old 05-17-2010, 07:10 PM
TOB.
Thanks kind if what I thought. Just wondering whats the purpose for the clips? Just for shipping ?
Old 05-17-2010, 07:26 PM
A930Rocket's Avatar
Just for shipping is all I can figure.
Old 05-18-2010, 04:58 PM
