Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 trans, how much oil?
1) Doing a search suggest you need a bit less than 4 quarts...
2) Doing another search suggest 3 quarts in any 915 transmission...
3) Reading Waynes book suggests you put in enough that you can touch the oil as you insert your finger in the side fill hole...
I did #3. But that took 5 liters from bone dry as the case was partly apart to reseal and fix a reverse issue. Any risk of an overfill? It seems that the fluid level is still below the main seal...
Should I drain out a quart, or leave it be? At 4 quarts, I had to put my finger in the fill hole and bend it downwards to touch oil. I can't imagine overfilling would cause problems, unless it causes drainage at the cv seals or the main seal...
Thoughts?
Old 05-17-2010, 04:52 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Was the car level? I usually install just under 4 qts, but sometimes lean the car to the right to get just a little more in. When it start to flow back out, I plug it up.
Old 05-17-2010, 06:08 PM
The trans was on an engine stand at the time...Perhaps I should take it for a drive, then open the side fill plug and see what comes out?
Old 05-18-2010, 05:07 AM
A930Rocket's Avatar
Yes. I would try that.
Old 05-18-2010, 03:55 PM
Thanks!
Old 05-19-2010, 05:10 AM
