Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
hipdoc's Avatar
79' 930 suspension
I have a 1979 930 and the front suspension/ steering seems sloppy. I lowered it and put a dump steer kit. Anyone have option about upgrade bushings - elephant racing, etc. It's for occassional driving but not racing and don't want to spent too much $$. Thx
Old 05-19-2010, 07:05 AM
Max Sluiter
Flieger's Avatar
Does it feel the same as your 993?
(by the way, it is called a "bump-steer" kit, not "dump" steer kit.)
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 05-19-2010, 02:44 PM
David's Avatar
I have elephant on mine and they work great, but they're not the cheapest option.
2014 Cayman S
2011 Cayenne Turbo
Old 05-19-2010, 04:53 PM
hipdoc's Avatar
Oops. Bump steer kit. Anything like Walrod bushings?
Old 05-19-2010, 06:51 PM
hipdoc's Avatar
I ordered the Walrod bushings for my 993. My 930 does wobble like my 993.
Old 05-19-2010, 06:57 PM
vmb vmb is offline
vmb's Avatar
I put on the polygraphite bushings on the front and have a lot of squeaking. If I drove mostly on the track I wouldn't care, but I drive 90% on the road. Maybe some lube would help though, or a few thousand miles? I did put on Elephant polybronze's on the rear, they are nice and quiet.
Vic
1979 930 with Rebel coilovers and many more parts on shelf to be installed.........
Honda Odyssey minivan parked under the turbo
former Tony//Kart shifterkart owner
Old 05-19-2010, 06:58 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
^^^ Did you use the lube and lots of it? I've got about 11k miles on my car with the urethane bushings without problems.
Old 05-20-2010, 04:33 PM
vmb vmb is offline
vmb's Avatar
yup, but apparently not enough!
Vic
Old 05-20-2010, 06:39 PM
Grab the top of the front wheels and give it the push pull thing to see if you have something else that is up?
What front springs, tires, toe, caster, and front bearing thrust? They all can impact how the front feels.
A strut top and tower brace might help. I love the SRP Camber King set up.
The front a arm bushings are just a small part of what effects the front.
Having said that, most 930's regardless of miles probably have the front bushings colapsed.
Old 05-21-2010, 05:44 AM
You might just need new tie rod ends and an alignment. Check air pressure and the front tires too.
After that it's just lots of fun upside down work removing the front suspension and cleaning everything and replaceing the control arm bushings.
Dirty job, not easy getting it all backtogether, and time consuming.. but very satisfying once it's all done.
Old 05-21-2010, 07:43 AM
