cam broke during install
How is this even possible? I was not even near the 110 ft lbs while tightening the nut and then it started getting loose again and then...
Old 05-20-2010, 10:22 AM
David's Avatar
Wow!!!
Is it a stock cam?
2014 Cayman S
2011 Cayenne Turbo
Old 05-20-2010, 11:15 AM
Infidel
JBL930's Avatar
Sorry to see that, i guess one bonus is that it didn't happen with the engine running!
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 05-20-2010, 11:23 AM
SAIGON 68
johnnywishbone's Avatar
my 2 year old grandson broke my wifes' bowling ball.
Old 05-20-2010, 11:45 AM
It was an SC profile from web cams. It was in the engine for years and then I sent it to web cams to get reconditioned and I was installing it again. They said they have never heard of this happening.
I had the torque wrench set for 110 but I am guessing I had about 75 on it at the time it broke. Yeah I guess it is better it broke now instead of later.
So I will be getting a new SC cam from them. I will need to pay the core charge since I don't have a good cam to send them now. Does anyone have a SC cam good or bad I can send them for a core?
Old 05-20-2010, 12:05 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
That's scary! I'd think about replacing both of them to be safe.
Old 05-20-2010, 05:52 PM
Yeah maybe. You know how it is, I just want it together again.
Old 05-20-2010, 06:10 PM
what? me worry?
TimT's Avatar
Send both cams out and have them machined for the later style bolt?
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 05-20-2010, 06:30 PM
It's possible it was overtightened by someone before you got the car and was tweaked.. and then let go on you.
Looks like black sand on the inside..
Old 05-20-2010, 07:01 PM
Wo ist die Rennstrecke?
DonE's Avatar
Wow - I wouldn't do anything with those. Looks like new cams for you. Thank your lucky stars that happened now and not on the street. Think thousands of $$ repair....
Old 05-20-2010, 07:28 PM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
wow thats nuts, i work on a lot of vw's and have seen 2 different guys snap cams in built VR6 motors but never any other car. sucks but good thing to happen before u started the motor.
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 05-20-2010, 07:32 PM
Drive it like u stole it.
jonesb930's Avatar
First time I have heard of one breaking like that. I had the old style but changed to the later style with my current build. The later style has some challenges to getting the cams timed with a high lift cam though. Here is the thread on the topic
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 05-21-2010, 04:36 AM
what? me worry?
TimT's Avatar
I actually had a cam break in the same fashion, was not too concerned regarding machining to the later style. Those cams ( the ones with modified nose) are still in use, and I'm not losing sleep over them
Figured after numerous installs and uncertain history of the cam a break from the root of the thread might possibly happen...
Timing the cams is always a sort of zen like experience.....
I'm posting from Huangshan, China so I figured I could say something like that
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
BBS wheels
Fikse wheels
Redline motors oils
Swepco
Old 05-21-2010, 06:01 AM
