bruni911's Avatar
check valve
Where can i find the check valve is it in top or the bottom of the egine?
Need to see if the car has one?
Old 05-23-2010, 12:11 PM
Bruni,
What check valve are you referring to. What year, type is your car. If your talking about the fuel pump check valve it's part of the fuel pump fitting.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 05-23-2010, 03:58 PM
bruni911's Avatar
Sorry its a 1987 930 i think its the one that goes to the turbo from somewhere i thinks its under the oil pressure switch but i do not know where that is either.
Old 05-23-2010, 06:05 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
maybe you are talking about the famous round ball in the temp sending unit, located at the right rear?
Old 05-23-2010, 06:31 PM
thats the oil pressure idiot light sending unit with the turbo oil line, etc under it in that diagram.
it's on the top of the engine in the middle towards the back of the engine bay under the fuel injection stuff next to the crankcase breather.
you'll have to at least remove the air cleaner to see it.
Old 05-23-2010, 07:07 PM
bruni911's Avatar
ya thats the one where is it located can i check to see if i have it?
The car has gone throw 2 rebuild turbos and now that i have the car it has a brand new turbo in it and the mechanic does not really now why the turbos failed?
So from what i have read it might be missing the check valve ball?
Old 05-23-2010, 07:08 PM
bruni911's Avatar
Is it a rear upper or lower?
Really i am lost
Thanks for your help
Old 05-23-2010, 07:09 PM
A930Rocket's Avatar
As you face the engine, it will be under and behind the fuel distributor. As Jim said, it's in the right rear corner, ON the engine.
Old 05-24-2010, 04:50 PM
Banned
Maybe this will help . . . this is a pic of the check valve assembly mounted on the engine (top, middle, near the firewall) . . .
Oil Scavenging Problems
Old 05-24-2010, 05:29 PM
bruni911's Avatar
thanks i found it
one more question does adding octane boost change the fuel air mix?
I would like to get a gauge installed
Is there any good books i should buy?
Thanks again
Old 05-24-2010, 06:01 PM
A930Rocket's Avatar
Higher octane willnot affect the air fuel mix. It will help prevent detonation though.
What kind of guage? An AF Guage? Look at Innovate products. You can get them installed full time or temp for testing.
Books? Can't think of any technical books other than the factory manuals.
Thanks again
Old 05-24-2010, 06:31 PM
Banned
thanks i found it
Thanks again
Four excellent books for all 911/930 owners are:
1) Porsche 911 Performance Handbook 1963-1998 3rd Edition by Bruce Anderson
2) Bosch Fuel Injection & Engine Management by Charles O. Probst
3) 101 Projects for Your Porsche 911 by Wayne R. Dempsey
4) How to Rebuild and Modify Porsche 911 Engines 1965-1989 by Wayne R Dempsey
The last two on the list are by the Pelican Parts CEO.
Old 05-24-2010, 07:41 PM
