Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Garage Queen
PorscheGAL's Avatar
Shifter knob separation
Folks,
My 87 930 has this 3mm gap on the front and back of the shifter knob. Is this normal?
Stephanie
My minions:'86 911 Targa 3.4, '87 930, '05 Lotus Elise,
'18 Macan S, '13 Focus ST, '16 Focus RS
Old 05-24-2010, 03:35 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Negative Ghostrider. It should be smooth.
Old 05-24-2010, 03:45 PM
Rocket Scientist
Mine is exactly the same, and I know how it got that way. Like mine, your shift knob was once leather covered, with only the shift pattern showing. The leather wore off and became loose, so someone cut it away just like I did to mine. After awhile I got sick of it and replaced it with a different knob.
Old 05-24-2010, 09:50 PM
Garage Queen
PorscheGAL's Avatar
Thanks guys. That make complete sense.
Stephanie
Old 05-25-2010, 02:14 AM
Boost Is Better
Turbology's Avatar
Back from the graveyard as not to spam the forum too much.
Can you folks tell me how the factory 930 shift knob is attached to the shifter? I've got a copolymer project in the works.
Is it threaded? If so, would anyone happen to know the thread pitch? Many thanks in advance as usual.
Boost Is Better
Old 02-08-2011, 09:17 AM
Champagne on Beer Budget
HelmetHead's Avatar
The shift knob is threaded..unsure of the pitch. Mine looks just like the photo above...no more leather.
Einar
87 911 Turbo
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 02-08-2011, 11:26 AM
Boost Is Better
Turbology's Avatar
Hi Einar,
Thanks so much for the reply and confirmation, that's a step in the right direction. I'm assuming it's of course metric. I would be very grateful if you had some way of determining the specific pitch. Thank you again for your feed back.
Boost Is Better
Old 02-08-2011, 12:31 PM
A930Rocket's Avatar
If it's like my 87, it uses a crush collar to keep it installed. I used an open end wrench just wide enough to go over the shift lever and tap the bottom of the wrench with a hammer to lift it up.
If it was screwed on, it would have a jamb nut or allen screw to keep it from spinning IIRC.
Old 02-08-2011, 06:29 PM
sudo apt-get purge 930
equality72521's Avatar
Same on my 1979 and every other I've seen.
--clutch-monkey
Old 02-09-2011, 03:01 AM
Boost Is Better
Turbology's Avatar
Many thanks for the insights guys, I sincerely appreciate it. Seems simple enough, and since the shifter itself isn't tapered, I should be able to just have the opening of the new copolymer shift knob machined to match the factory dimensions.
Sorry to nag about it, it's just that the car is in CZ which is six hours ahead of us so it can be difficult to catch the guys in the shop and have them take the measurements directly.
Boost Is Better
Old 02-09-2011, 05:15 AM
oilonly's Avatar
Hold on! My '87 you have to carefully pry off the the top cap and then you unscrew a bolt and the shifter comes off.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 02-09-2011, 03:14 PM
A930Rocket's Avatar
^^^ I could wrong then. I know I did it to either my 911SC or my 930.
Old 02-09-2011, 04:40 PM
Boost Is Better
Turbology's Avatar
You're both right!
'86 and older
'87 and newer
Boost Is Better
Old 02-09-2011, 04:47 PM
Boost Is Better
Turbology's Avatar
We've got some aftermarket junk knob in our car, so if any endeavoring soul would be kind enough to measure the depth and diameter of the opening of a factory '86 and older shift knob, I would be much obliged.
Boost Is Better
Old 02-11-2011, 05:19 AM
Questions on this thread thread for my 79 930.
I have the crush sleeve.
Question do I need to totally remove the shifter to avoid damaging the shifter mechanism to separate shifter knob from shifter?
Taking a wrench and a hammer and beating on it sounds like it would damage the shifter mechanism if it was left assembled.
I guess I'm asking if I need to totally disassemble the shifter mechanism to safely remove the shifter knob as you would have to use a hammer and wrench to remove it.
Old 09-29-2017, 08:33 AM
