Hi-Torque Starter will solve this issue
Bosch starters are CRAP !!!
Old 06-01-2010, 02:00 AM
mark houghton's Avatar
Originally Posted by Hirevtuner View Post
Well maybe not zero. I removed the gauge at 1 bar but it did drop fast.
Do you think the fuel head would be the offender? It runs great once started.
I don't know why your pressure would change so drastically due to heat, but who knows? It can't hurt to pull the regulator out of the fuel distributor. If it's all gummed up, it might be an indicator of the general condtion inside the fuel head.
I'm still not clear if you're referring to the system pressure or to the warm control pressure (the control pressure being established by the WUR). If you're talking warm control pressure dropping off to less than 1 bar, I would think your WUR is at fault (I know you've replaced it, so...?).
Somewhere you have fuel pressure bleeding off. I would point you to the ball check valve at the front pump, but you've already replaced it as well.
Currently stumped....
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 06-01-2010, 09:08 AM
full quack's Avatar
Send a message via Yahoo to full quack
Well I still say it is most likely a bad injector seating issue.
So what you have is fuel pressure leaking off from the system when turned off hot, while at the same time causing a flooded engine condition.
If you let it sit for a short time 5-10 minutes, it has not leaked off enough fuel yet to cause flooding & you still have some pressure, so it starts.
You let it sit for say 20-30 minutes, & enough fuel has leaked that you have zero pressure + a flooded engine, so you crank & crank till it's clear & you have fuel pressure, then it starts.
This does not show up as a symtom when cold either, because the leaked fuel has evaporated & the cold start valve blasts enough fuel in the get it fired up while the pumps come up to pressure.
my .02 cents worth
Mark
Old 06-01-2010, 12:36 PM
Had the same problem, finaly decided to just replace all six injectors (minor cost realy)
Old 06-01-2010, 08:29 PM
Hirevtuner's Avatar
Thanks guys. I'm thinking I do have a bad injector that is bleeding down at rest but under running pressure is not causing me grief. I will get another set and give them a try.
1981 411 rwhp, Ruf intercooler, 964 cams, Turbo Kraft injector blocks, Extrude honed intake, 7006 Turbo, Tial wastegate, RarlyL8 exhaust, MSD6al
Old 06-02-2010, 04:58 AM
wjfk32's Avatar
Poor mans way out...Try some mmo-in the fuel...
worth a shot, and not costly.
Walt
Old 06-02-2010, 06:25 AM
