Is This The Later K27 ?
Here it is.
Old 06-02-2010, 03:30 PM
dhg1337's Avatar
I don't know, but is sure looks nice. what does something like that cost?
1977 930,no mods
Old 06-02-2010, 03:36 PM
Looks like an older one thats never been used.
The newer ones I've seen don't have KKK in the casting anymore since Borg Warner bought them.
Old 06-02-2010, 05:53 PM
It has a 7200 number and fron what Jim is saying it might be an old stock K27-7200.
If so a very nice turbo forup to about 350 whp. (400chp.)
Old 06-02-2010, 06:45 PM
Yep it is a brand new turbo never been used. I am going to replace my K26 with it (just waiting for new gaskets). Can hardly wait to see how it runs with it
Old 06-02-2010, 06:57 PM
never seen a new old one
only thing that throws me a little is the green paint. not sure thats origonal but the etching on the hot side gasket flange sure makes that part look new.
Old 06-02-2010, 08:11 PM
89 930.
Benny771's Avatar
My "new old" 3ldz I got off of ebay has the same green paint.
Old 06-02-2010, 08:50 PM
Crotchety Old Bastard
RarlyL8's Avatar
I would be inclined to believe this is a rebuilt turbo. The housings can be blasted or tanked to look brand new. The green paint is typically an assembly torque spec verification. You can purchase new tags.
Really makes no difference as rebuilt should be good as new.
I carry new K27-7200's for $1295.
You will really like this turbo as compared to the 3LDZ.
Old 06-02-2010, 09:10 PM
The person I purchased it from guaranteed its new. Came in the sealed original box in plastic with papers.
Old 06-02-2010, 09:40 PM
Did not know that. When did they stop putting on the "KKK" ? Kind of like the "KKK" on there makes it more period if you know what I mean.
Old 06-02-2010, 09:50 PM
Rocket Scientist
That is for sure a brand new Porsche 964T turbocharger. Search my other posts for my turbo part number list.
Just a few other comments. The 5327 988 7200 has the K27.2 turbine wheel. The 5327 988 7006 uses the K27 turbine wheel (and a different compressor), so they really are different turbos. Calling them K27 7006 and K27 7200 is quite misleading to most people in this regard.
Also, I saw on the other referenced post a couple of comments about 999 in the part number. A 999 means that it is a service part. As you can see from my list, racing turbos also had full part numbers, just like production.
Old 06-03-2010, 06:42 PM
RarlyL8's Avatar
As stated previously, new castings do not have the KKK logo and the part number on that tag is for a 964T. If this turbo is not rebuilt and has never been used it is not new but old. It has just never been used.
Old 06-03-2010, 08:09 PM
So it is Ole New Stock, instead of New Old Stock.
Old 06-04-2010, 06:54 AM
Rocket Scientist
The one I bought in 2005 still had the KKK's on the castings and the nameplates. I have seen some new ones that have just one K on the nameplate, and some from China that have the Borg-Warner nameplate, but all still had the KKK's on the castings.
The one I bought in 2005 came in a box that said Borg Warner Turbodriven. BW bought KKK in 1998.
Can someone post pics of a K27 with no KKK's on the housings? I think this would matter a lot to some restoration people.
Old 06-05-2010, 04:56 AM
Rocket Scientist
Also, the 988 in the application number indicates a new replacement turbo. The date code is right in front of us here, but I can't find my decoder sheet! I might have to ask for a new one.
Old 06-05-2010, 05:17 AM
K27 Is Mounted
Thanks for all your help guys! I wound up buying the OE Porsche bracket for the K27 as someone here suggested. For $130 bucks did not feel like cutting/welding the old one. Got the K27 mounted and the engine is ready to go back in. I can hardly wait to drive it with the new turbo.
Old 06-16-2010, 09:47 AM
Rocket Scientist
That is a beautiful engine. Did you do all that?
Old 06-16-2010, 07:10 PM
Thanks. Yes I did
Old 06-17-2010, 09:30 AM
Infidel
JBL930's Avatar
And the award for the cleanest engine on earth.... goes too.....
Wowzers, is that covered in silicone spray or something, it's uber clean
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 06-17-2010, 10:20 AM
No silicone here. Just elbo grease and replaced old rubber etc..
Old 06-17-2010, 11:47 AM
