clutch
Does a clutch dry out ? Unfortunetly I do not know the type of clutch I have in my car though my pedal is stiff and I just replaced my cable springs and rebuilt my pedal cluster. The clutch was replaced in my car in 1995 and has 10000 miles on it.Any ideas?Engine drop yikes
Old 06-04-2010, 08:09 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
make sure it's adjusted correctly. the fact that it's "tight" might mean it never fully engages
and no they don't dry out..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-04-2010, 09:16 PM
Don't forget to lube the throw out bearing grove (accessible through the inspection cover on the side with the drivers side rear wheel removed). I had a very hard pedal that stuck down occasionally and a little squirt while a friend was pumping the clutch fixed it. I need to do it again with a longer lasting product like chain wax or lithium grease.
Old 06-05-2010, 01:51 AM
gumba's Avatar
Did you adjust the return spring on the pedal cluster?
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 06-05-2010, 06:41 AM
I did use some lithium grease on the throw out bearing. also the pedal spring works well (its tite)
Old 06-05-2010, 07:47 PM
