LinkBack Thread Tools Rating: Thread Rating: 11 votes, 2.73 average.
Originally Posted by Ronnie's.930 View Post
No, that would be me!!!
Since you've verified that you're getting fuel, and that the CDI box whines when it is supposed to, the next thing you might consider doing is disconnecting one of the spark plug leads, putting a spare spark plug in it (ground the plug against some nearby metal) and engage the starter to see if you have spark. If not, it could be that one of the coil wires is not connected, the green CDI-to-distributor wire is disconnected or damaged, or the coil itself is bad.
Yes, I need to do the spark test, have not been able to do that yet. I verified the coil to distrib wire is tight at both ends, it did notice that the two leads coming from the CDI unit are somewhat aged with some bare wire showing which needs to be fixed.
Are the any multi-meter tests I can do on those two leads to verify good back to the CDI unit?
The car ran beautifully before I started work, which is why I've avoided replacing ignition components yet, other than the plugs. I have a new harness, cap, rotor, and blaster II coil but I really think its something simple/stupid and that replacing parts is just shooting in the dark.
Just reread your post Ronnie, the green wire I thought was an RPM sensor on the dizzy, I did replace the fan housing strap and I know it was super tight in there, I will verify that isn't damaged somehow.
Old 09-20-2015, 08:59 AM
Another data point
Something else just occurred to me while researching this. When I acquired the car the tach needle would jump around, as I drove it now and again for a few months that jumping around got worse, sometimes the needle would even totally die or peg.
At the same time I had headlights that would dim and brighten with engine RPM, which is why I replaced the alternator (went with one of the 160 amp units). I thought that a bad VR would cause those tach issues. The engine did not miss or have any rough running or power issues when the tach was misbehaving.
Is it possible that it wasn't alternator at all? That something else was failing that might now have completely failed and be preventing spark?
Old 09-21-2015, 06:14 AM
T77911S's Avatar
It's better for everyone to start their own thread for their issues and just leave this one for instructions on how to trouble shoot or for reference.
A jumping tach would indicate a charging problem.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 09-21-2015, 06:57 AM
Also check to make sure the PO didn't use cheap ass no good crimp connectors to join critical wires together.
Solder and heat shrink.
Old 11-12-2015, 10:09 AM
Hi Bill, great thread can you please send the pdf to me via paul.nixon@mammoet.com
I'm having some issues, and thought I would go back to basics and check everything, my car was running great in all conditions hot cold in traffic under boosts etc then one morning it didn't want to start after spluttering into life I thought I would give some of your checks ago, it's an 86 3.3 coupe USA spec from Japan with all of the air injection removed.
Firstly my over boost is open circuit and not closed.
The yellow relay can be in our out and no difference.
The air flow switch is normally closed but does not open when I activate the air flow plate
Yet the pumps run from the ignition and I cannot find any evidence of a jumper.
Any thoughts paul.
Old 02-21-2016, 05:24 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Hot start problem
Great thread - curious why hot starts were not mentioned specifically - last time I drove the car -pit ran great . After about an hour I stopped for coffee. 20 min later car wouldn't start. 30 minutes later - car fired up and ran great.
I was under the impression from all posts that it could be accumulator or WUR.
Over boost is grounded and there is no over boost relay in car. Car was highly modified by OO
Old 05-03-2016, 06:54 PM
Me like track days
Craig 930 RS's Avatar
MZ3 - what did yours turn out to be? having the SAME problem! See my post from this morning
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-10-2016, 11:28 AM
Me like track days
Reviving a 930 - fuel delivery after warm shutdown and then startup - whats up?
Old 06-10-2016, 11:29 AM
very impressive thread, would be appreciated if could have more updates like heavy car is better or not...
Old 09-05-2016, 07:20 PM
This has been really helpful, thanks a lot guys
Old 12-28-2016, 02:22 AM
CDI ( Brain Box )
Photo ( before ) recent Pelican refurbish.
Plugg and play one 6 pin connection
Scott D Anderson
88 930 Turbo
74 914 LE Bumble Bee
Old 09-23-2017, 11:18 AM
hey
Old 01-31-2018, 03:36 AM
You might not agree but distinct cars have their own different troubles which forbid their start. You could have a view to this in your user manual and if you do not possess one, you could get one for your car from ‘manuals.co’ who store all kinds of car manuals.
Old 01-31-2018, 04:43 AM
I thought I would write up the common items to check when our cars won't start or run well. If everyone could copy, paste and edit my start, we could have a good start to a Sticky that new and old owners alike could check or if you have a better idea, go with it.
Adding explanations, links and pictures would be great to show or explain further.
When done, we can get the mods to sticky it to the top.
I could of used this this past Wednesday when my car left me stranded. The car wanted to turn over.... but the pumps were silent. Luckily I was a block from a mechanic buddy and he got me going. Of course he was silent about how he got me going. He said he had a "cheat" way of doing it.
I am assuming this is the way.
For more Visit corporate film production
Old 04-09-2018, 10:56 AM
Pirate Rhum
premdes's Avatar
Wiring order, distributor 82 911sc
Finally took a stab at doing tuneup on my car. I did entire list of basic replacements, such as rotor and cap, spark plugs (Bosch wr5), pulled all injectors, cleaned and revealed. And of course valve adjustment.
I could have sworn when Z1 on pulley was aligned with notch, my rotor was pointing to 2o'clock if the two side tabs for distributor cap is at 9 and 3. I just double check d and it is 180 deg (7oclock). What am I missing,
Also I assumed wires went back on cap, same firing order (ccw). 1-6-2-4-3-5
Perhaps this is what's causing the car not to start to correct my mistakes.
Any help is greatly appreciated.
Amir
911% lifestyle
Old 04-28-2019, 11:24 PM
Z1 is TDC for #1 and #4
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition, and EBC. SC cams, K-27/29, Tial 0.8bar, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 04-29-2019, 06:45 AM
