Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
77 Turbo hot start problem
I drove the car to pick up my daughter for dinner yesterday. Stopped several times, and didn't have any issues restarting the car. The last stop i made was to drop her off, and shut the car off for about 5 minutes, not unlike the previous stops. I o back out to re-start the car to drive home, and I could not get it to start. Cranks no problem.
Everything is very stock on the car. The engine was rebuilt last summer, and has less than 1000 miles on the rebuild. The fuel head was rebuilt, the WUR was rebuilt also
One thing that I did notice, when I turned the key to start the car, the fuel relay in the back was opening and closing very quickly, and continued to chatter for a few seconds after I stopped cranking the engine. I tried to swap the relays from the front to the back, checked the fuel pump fuse, and nothing helped.
I sat there for just about 1 hour with the engine lid open. I was on the phone with Haggerty for a tow and tried it one last time, and it fired up.
I have read some other posts regarding hot starts, but didn't see any comments of the fuel pump relays chattering open and closed.
Would this also be the fuel accumulator like I have read in other posts? Is the CDI unit going bad? Any thoughts would be greatly appreciated.
Karsten
Karsten
1977 Turbo Carrera - Work in progress
1971 911E Targa - Almost gone
Old 06-10-2010, 05:15 AM
Turboo934's Avatar
I've had the same problem, turns out to be the overboost switch wire. Hope that helps.
Robert. 1976 930/934 Turbo Carrera RRS, Cristine She can be evil but oooh so much fun
Old 06-10-2010, 06:41 AM
Thank you. Dumb question, but were would the overboost switch wire be?
Karsten
Old 06-10-2010, 06:53 AM
Turboo934's Avatar
On the BOV.
Old 06-10-2010, 07:01 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
See the STICKY....
Old 06-10-2010, 11:41 AM
That STICKY is great! Thanks for starting it. Helps to clarify a lot of questions of where certain parts are.
Karsten
Old 06-10-2010, 04:08 PM
lite75's Avatar
+1 on the fuel accumulator.
In a pinch you can push down on the air flow sensor plate 1 or 2 seconds while the key is on and it will start right up.
75 930, 76 930, 83 SC EFI turbo
Old 06-10-2010, 09:47 PM
Rob,
What was the issue with the overboost switch wire on your car that caused an issue?
Karsten
Old 06-11-2010, 11:10 AM
Turboo934's Avatar
Old connector.
Old 06-11-2010, 11:19 AM
Very good. I'll clean it up tonight. It looked alright when I checked it at lunch.
Would this connector also cause the rapid opening and closing of the fuel pump relay? That was one fo the things that was really obvious when I was trying to start the car. It continued for a coulle of seconds after I turned the key off.
Karsten
Old 06-11-2010, 11:41 AM
