Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Me like track days
Craig 930 RS's Avatar
Question Correct alternator?
Is this absolutely 100% the correct alternator for my 1982 930 with internal regulator?
http://www.******auto.com/ShowItem/1665%20Porsche%20Alternator%20New%20-%20Valeo%2075%20Amp.aspx
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-10-2010, 12:12 PM
Me like track days
v ertex
Old 06-10-2010, 12:18 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
From the application guide at the bottom of the webpage, it would seem correct. The picture also shows the internal voltage regulator.
I've gotten 1 or 2 from V.ertex in the past and been happy.
EDIT, to look at the link, you need to sub in v.ertex with out the dot for the ******'s.
Old 06-10-2010, 01:35 PM
Craig, I happen to have a 79' 930 engine apart here and I checked the part number for the alternator.
It is also 911 603 120 04.
Hope this helps.
Also, does anyone know if the later 84' and up alternator will work? And if so, is it an improvement?
I am not sure, but by the picture here on P.P , it looks as if the newer one has a better heat-sink design for the diodes and voltage regulator.
Old 06-10-2010, 03:12 PM
A930Rocket's Avatar
Later model alternators will work, but you will need to update to an internal voltage regulator. That said, it's really just some wiring. I think there is a bulletin on it.
Old 06-11-2010, 10:01 AM
Me like track days
This the right one? In my cart here at Pelican:
Paris Rhone 75 Amp New Alternator, 911/911 Turbo (1975-83) (may need 911-603-428-01-M100, if updating. See Tech Bulletin), Brand: Valeo
- Core charge may apply in addition to price.
[More Info] [Choose alternate brand] $331.50 $331.50
Old 06-12-2010, 01:23 PM
A930Rocket's Avatar
That's the right one. The update is attached.
For the air guide, you can modify you old one if I'm not mistaken. Just need to slot the bottom.
Old 06-12-2010, 03:55 PM
Me like track days
Perfect guys, thanks a TON for the help!
Old 06-13-2010, 08:32 AM
Ken911's Avatar
might as well go ahead and get the 90 amp one
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 06-13-2010, 05:06 PM
