Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
exhaust advise
In the next week I am going to swap out my stock cat/exhaust, and 3DLZ . I am going to install K-27, B&B dual out muffler. Will this install have any heat effects on the bumper? I do not know if the stock heat shield can remain with the aftermarket muffler. Should I install a heat shield/pad? Or will this free flowing system actually run cooler than the stock application. Any input would be appreciated. Thanks Philip
87 930 GHL/Rarlyl8 dual/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LC-1/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin plug coil packs/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo install in progress. 500+ HP, BTSOMP Dyno
Old 06-14-2010, 01:50 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
It should work with the stock heat sheild. That said, it can still get hot.
My GHL's with a B&B single outlet muffler and K27-7200 (or HFS, can't remeber) got hot enough at the track to melt the left side bumperette at the bottom.
Old 06-14-2010, 03:22 PM
Wo ist die Rennstrecke?
DonE's Avatar
You should be ok.
Old 06-14-2010, 05:41 PM
