Garrison's Avatar
Torsion Bars
Is there a preference of which manufacturer to use? About to pull the trigger on a set up and am wondering if I should go with Sanders bars over Sway-Away? Solid or Hollow?
Any thoughts would be great.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 06-17-2010, 07:15 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Sanders has a good reputation for quality. That said, I've had Sway a Way for 10 years with out problems. For solid vs hollow, I think it's more of a weight issue, unless you are getting the largest hollow bars, which might have an effective rate higher than the largest solid bars. Unless you're tracking the car at the highest, I doubt you would need the hollow bars.
I'm using the largest solid t-bars I could find when I installed mine years ago. IIRC they are 23 and 29 mm.
Just my .02
Old 06-17-2010, 11:34 AM
Garrison's Avatar
Yeah this car is going to be 80-85% street, 15-20% DE/track so I am not going crazy on the T-bars, 23/30.
Thanks for the help.
1996 Porsche 911
Old 06-17-2010, 11:42 AM
Max Sluiter
Flieger's Avatar
If you are using bars so large you are limited by torsion tube diameter, solid bars will have a stiffer spring rate because they have more metal in the same outside diameter. Equal diamters- solid bars stiffer. Equal effective stiffness- hollow bars lighter (but bigger).
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 06-17-2010, 11:43 AM
Me like track days
Craig 930 RS's Avatar
IMO a 930 cannot ever have too much rear spring rate.
These cars NEED large bars, balanced of course by large fronts -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-17-2010, 12:22 PM
Garrison's Avatar
I am doing 23/30 solid bars. With Sway-Away the biggest you can do in the rear is 31 solid or 33 hollow.
1996 Porsche 911
Old 06-17-2010, 12:26 PM
David's Avatar
Hollow bars are only slightly larger than solid bars, maybe 1/2 a millimeter. But big weight is pulled out of the center. My 31mm hollow rear bars weigh a little less than the stock 26mm.
Of course you pay for that weight savings.
2014 Cayman S
2011 Cayenne Turbo
Old 06-17-2010, 12:53 PM
