bruni911's Avatar
Bad fuel smell. Need help
1987 930
Hi when my car is off it's smells like fuel really bad, I checked for leaks but could not find any I have narrowed it down to the rear fuel filter area there is also another filter beside the fuel filter I do not know what it is? Even when I am driving the car I can smell fuel the gas tank seems fine
any help will do
Old 06-17-2010, 05:53 PM
bruni911's Avatar
Another question what is a WUR ? everyone talks about it what is it
I am a Nebie
thanks
Old 06-17-2010, 06:09 PM
89 930.
Benny771's Avatar
1st, Fuel smell could be your vapor canister in the pas wheel well. I think mine is gone.
2nd WUR is a "warm up regulator", By the readings a huge issue for these cars and a new one is like $1000. Its used to adjust the air intake when the car is cold. I think.
Old 06-18-2010, 07:09 AM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Actually the WUR controls the fuel pressure all the time, it's very critical.. There are new digital ones now available aftermarket.. for about $700
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-18-2010, 07:27 AM
wwest's Avatar
Make sure you have good/new crush washers at both the top and bottom fittings for the fuel filter, common problem.
Old 06-18-2010, 08:43 AM
89 930.
Benny771's Avatar
I stand corrected.
Old 06-18-2010, 05:14 PM
bruni911's Avatar
Hey Benny where are you located in Ontario, i am in Hamilton?
Old 06-19-2010, 08:46 AM
trevs911's Avatar
Look for pin hole leak in fuel line when car is running.Mine was in the fuel line right above the
heater flapper box ,not good, saw it when i put in a new rear fuel pump in and did a leak check.
Could not see leak when car was on ground, because fuel stayed on heater box.
Car was on a lift when i found it. might be same for you.
Old 06-30-2010, 11:37 AM
