77 930 Clutch Cable Pic Needed
Anyone have a pic of how it mounts to the trans? Seems like the 1976-1977 cars have a different cable than the 1978 and later models. Think I have the later cable and the new one I got is different. Would like to put the proper one on as I always thought the clutch travel seemed funky.
Old 06-12-2010, 03:35 PM
Picture of new one on left and the one on the car is to the right with the threads. Just want to put the correct one on.
Old 06-12-2010, 03:42 PM
A930Rocket's Avatar
The right one is definately for an 87. Here a pix of my car.
Old 06-12-2010, 04:00 PM
Thanks for the picture to compare.
Was hoping someone had a pic of the 1977 set up as well.
Old 06-14-2010, 05:52 AM
Lurkasaurus
turbocarrera's Avatar
My new cable arrived today and looks just like your new one - it's the one listed for the '76-77 in the PET but my old one looks like your old one and A930Rocket's.
Maybe our cars were updated with the hooked-end '78-88 turbo cable? I have no idea how to make this other cable work.
Tony '77 930
"Objects in mirror are losing"
"Oh cock..." - James May
Old 06-14-2010, 10:39 AM
A930Rocket's Avatar
Maybe someone has retrofitted the clutch lever arm and support? Can it be retrofitted back?
Old 06-14-2010, 11:57 AM
I think the original style cable was not available for a while and people put on the newer one. Not sure what the effect of the newer cable is but my pedal on my 1977 always felt funky compared to my 1982 930.
Since we don't have the original old cable we need the correct end to put on the new cable . I ordered the rubber sleeve 311 713 269 A, end piece 911 423 205 03 and nut N 011 007 3.
Old 06-14-2010, 04:58 PM
I thought the same thing but the arm on my car looks like the original one. Like I said above I had to order a few pieces that the new 1977 style cable does not come with. Keeping my fingers crossed
Old 06-14-2010, 05:00 PM
Lurkasaurus
Doh!
I think you're right. Oh well, I've felt stupider before. I think I'll order that stuff too.
Tony '77 930
Old 06-14-2010, 09:59 PM
77 930 clutch cable
Hi, I gave a 930 77 Tranny and recently ordered the cable from our host (PP), part number:
930-423-401-05-M74
It had the rubber booty and hook end already on it. Below is a photo of it installed. I couldn't get my helper spring setup correctly, so I don't use that part of the clutch setup anymore. Seems to work just fine without it.
I hope that helps, Mike
1984 930 Cab LS6 Conversion
www.kingham.com/porvette/
Old 06-21-2010, 07:14 AM
