Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Canucks Fan
Question Does your engine cover lift by it's self?
Saw a vidieo clip and when the guy poped the rear lid it lifted by itself???
87-930 stock tail, when I pop the rear lid it just un latches, is that the way they work, you have to lift the lid, or it suposed to open when un-latched?
What does yours do.
Old 06-18-2010, 04:34 AM
sudo apt-get purge 930
equality72521's Avatar
Mine does the same as yours.
--clutch-monkey
Old 06-18-2010, 05:09 AM
I just installed...
4 new shocks on mine and it still lifts the way yours does!
87 930 GHL/Rarlyl8 dual/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LC-1/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin plug coil packs/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo install in progress. 500+ HP, BTSOMP Dyno
Old 06-18-2010, 05:47 AM
Non User
infraredcalvin's Avatar
Me too, and i have a lighter turbo carrera whaletail...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'74 914 track basket-case
Old 06-18-2010, 06:54 AM
R.I.P.
drmatera's Avatar
mine just pops as well. but once i lift it up a few inches the shocks take over and push it up.
we are talking about the car right? if not, try Viagra
Old 06-18-2010, 06:56 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I have to do a reach around to get mine to pop up while pulling on it. Maybe it needs lube or something? When it does pop up, I need assistance from a prop rod. Oh! the days when my shocks were young and spry...
Old 06-18-2010, 07:06 AM
mark houghton's Avatar
A simple adjustment to the spring tension on the latch post should solve that. Just screw in the shaft that runs through the spring to put more pre-load on the tension. Then when you pull the latch cable the lid should pop up with more authority.
A word of caution: Make sure the shaft isn't bent, which will cause the tension to load off-center in the latch...and may hang up and not release when you pull the cable. Been there, done that when I first attemted to adjust things back there. Couldn't get the lid to open at all, and there is no way to get to the latch to force it open in such an emergency. You're basically f - - ed if that happens. You have to resort to giving the lid a bear-hug and wrestling it sideways/up and down/round and round with all your might to get the lid open again.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 06-18-2010, 10:18 AM
A930Rocket's Avatar
I hear ya. With all the wirk I've done, this piddly thing just keeps getting put off
My next work out will be checking the front tires. They both lose all the air in a week. They are 3 piece BBS race wheels I installed new tires on 6 months ago.
Old 06-18-2010, 12:32 PM
Tinkering Pays!!
mooney265's Avatar
no wonder you 'hesitate' to take a trip in it...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 06-18-2010, 06:01 PM
Driver
Noah930's Avatar
Oorg. I just had a similar problem with some new 3-piece wheels. One had a slow leak. I wound up taking off the tire, then stripping the silicone bead from between the two wheel barrels (what a PITA) and re-siliconing a new bead. Problem gone.
Oh yeah, my rear decklid just pops open with the release, and then I have to lift it up manually.
1987 Venetian Blue (really looks like grey) 930 Coupe
Old 06-18-2010, 07:45 PM
I just recently installed new stabilus shocks while replacing the engine pad with a new lightweight one from our host.
The engine lid still needed a boost for the latch to release. After adjusting the position of the latch , it now works fine. The lid should not lift by itself until its lifted about 8 inches or so.
You have to be real careful in adjusting the position of the latch rod, if it jams in the lower jaws or is incorrectly aligned, you could be in for a long day trying to open the lid.
I had another 930 a few years back that i installed another spring inside the original spring to assist in getting the lid to pop open, that did the trick.
1978 930 Eurocar, steel slant. k27HS, Powerhaus IC, SC cams, RarelyL8 muffler.....,
2002 Mercedes CLK55 AMG Cab, chipped,
Previous and dearly missed:
1965 911S, 1970 911T, 1974 911S, 1978 930, 1982 930, 1950 Mercedes 300, 1988 Mercedes 560 SEC Convertible
Old 06-19-2010, 05:37 AM
Yep, BTDT. Anyone within earshot of my garage that day would have heard harshly spoken words in reference to female dogs, women of the night, female anatomical regions, and other such well chosen pornographic descriptive phrases. Drove me to drink heavily to gain the courage and strength to wrestle the lid enough to pop the top. Since that episode, I've installed a remote wire-pull on the latch, tucked behind the muffler, just in case the latch doesn't un-latch or if the cable should break.
When adjusting, do it a little at a time or you'll be sorry.
Old 06-19-2010, 11:16 AM
