Canucks Fan
Question Changing the motor mounts, 87 930
How do you get to the small bolts???? what has to come off to reach them?
Old 06-20-2010, 09:59 AM
If you mean the 10mm nuts on the bottom side, removeing the heater hoses on both sides will make some room to get a wrench under there.
Thats after removing the long bolts and cross bar and lowering the motor a little. If the large bolts are corroded stuck in the ends of the cross bar use an impact wrench or the bar will probably twist with the bolt and bend at the ends.
Old 06-20-2010, 10:40 AM
