-   -   Installing RSA carpet and found this.. (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/548990-installing-rsa-carpet-found.html)
equality72521 06-20-2010 10:02 AM
Does anyone know where these wires go? They are located under the driver seat.
http://forums.pelicanparts.com/uploa...1277053289.jpg
http://forums.pelicanparts.com/uploa...1277053301.jpg
JFairman 06-20-2010 10:31 AM
whatever it is, someone added it and it burned up.
happens all the time.... isn't electrical stuff fun?
to help guess, it would be better to back up or go wider so people can see the rest of whatever is under your seat.
there's also a piece of wire insulation from somones electrical adventures.
equality72521 06-20-2010 11:38 AM
Here are closer shots of how they were connected. I've added spade terminals to reconnect them until I find out what they go to. Oh, they WILL be insulated before going back.
http://forums.pelicanparts.com/uploa...1277058861.jpg
http://forums.pelicanparts.com/uploa...1277058877.jpg
http://forums.pelicanparts.com/uploa...1277058890.jpg
This end goes through the spooge seen here. The other end goes into the front fuse box area.
http://forums.pelicanparts.com/uploa...1277058906.jpg
The rest of the wiring you see is for my Innovate LC-1/SSI-4 installation.
Jim2 06-20-2010 11:55 AM
Modified wiring to rear fuel pump? The pump is in the direction where the wires are headed.
A930Rocket 06-20-2010 12:12 PM
Four different colored wires? Anything electrical/aftermarket you have in the engine compartment? What about a fuel enrichment device in back?
It's certainly been added, as nothing runs through that hole in the stock configuration. In fact there is ssupposed to be a rubber grommet there.
equality72521 06-20-2010 12:24 PM
The only thing was an old alarm system siren and lid switch I think I completely pulled. Hmmm.
equality72521 06-20-2010 12:56 PM
Ok, everyone, thanks for the ideas but you can stop now. I assume it was part of the old alarm. The end that went toward the engine was taped off and tied to a bracket near the driver side brakes. The two gray wires went to each rear wheel and was cut off. The other end went to front of the car and was lopped off. I just pulled it all out.
