belt alarm, 930- 3,3- 78
Hello. it sounds very strange. but when I accelerate quickly Starter
belt warning alarm, but only in period. I have tried anything so, and what the fault may be??
sincerely john
Old 06-25-2010, 02:13 PM
sudo apt-get purge 930
equality72521's Avatar
Sounds like a slipping belt if I understand correctly. Have you checked it? Is it loose? Is it glazed? Is there any oil on it?
--clutch-monkey
Old 06-25-2010, 02:30 PM
I have checked the link belt and it is not there fault, there must be something else affecting the system.
Old 06-26-2010, 02:51 PM
The only belt alarm I have seen is on 911 race cars.
There was a hose coming from a small fitting on the fiberglass part of the fan/air shroud and a map sensor of some sort was attached to that. It would sense the slight air cooling pressure loss and light a dash light if the fan belt broke during a race.
If thats not what you're talking about I have no idea what you mean by a belt alarm.
Old 06-26-2010, 03:50 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Spray a little WD40 in the belt. If the squeak goes away, you need a new belt and/or adjustment.
Old 06-26-2010, 08:17 PM
Hello. excuse me I have not explained myself clear enough. sometimes under heavy acceleration lights safety belt warning system and audio warning sound comes (buzzer) I have checked Seat belt switch, it must be something else affecting the buzzer and belt warning system.
Old 06-27-2010, 02:42 AM
lol... ok that explains everything.
there are a couple wires and plugs you have to disconnect when removing a power seat. one plug is for the power seats and the other is for the seat belt warning system or belt alarm if that helps..
if it was mine maybe i would probably rename the little red dash light to: Hang On.. and the buzzer would be eliminated or turned into a sultry female voice saying: yes! yes!.
Old 06-27-2010, 10:42 AM
Old 06-27-2010, 12:28 PM
All I can say is check all connections to make sure they aren't bad.
--clutch-monkey
Old 06-27-2010, 01:04 PM
