RarlyL8 wastegate muffler
Just finished installing Brians (rarlyL8) wastegate muffler. After snapping all 4 studs then having to get them drilled out and replaced and then replacing the wastegate spring from a 1 bar to a .7bar, a 1 day project turned into a 1 week project. Damn life gets in the way.. lol..
Finally got to take it for a test drive after it sitting for a while. Well you know when the wastegate opens up now. Its not much louder over the zork tube, but adds a nice "extra" to it. LOL.. thanks again Brian for the excellent piece of engineering and welding. http://forums.pelicanparts.com/uploa...1278393498.jpg http://forums.pelicanparts.com/uploa...1278393534.jpg http://forums.pelicanparts.com/uploa...1278393628.jpg I did a hasty job in painting the housing. I know i should have painted it while it was off the wastegate but my friend that helped me had to leave so we had to reattach it before he left. lol.. |
Not much of a "muffler", ha!
Sounds like you had about every obstical possible. You should hear these with a stock muffler; pretty cool Jeckle/Hyde. |
I've got the same dump pipe. It sounds good and it seemed to flow a lot better than the factory set up (on my '79 the wastegate was plumbed into the muffler).
http://asbury.smugmug.com/By-Land/Po...24_ygDKm-L.jpg |
Great photo. What kind/year exhaust is that?
Can someone annotate these letters for me with the correct names? http://forums.pelicanparts.com/uploa...1278441293.jpg Here are my guesses: A: Muffler B: Exhaust pipe (why is it so long and go across the back of the car?) C: Turbo peeking through D: ? Turbo drip tank? If so who makes this one? E, F: Heat exchangers G: Wastegate "muffler" H: Wastegate: factor? What year? Otherwise who makes it? I: Heat exchanger outlet not connected yet, goes to passenger compartment? Thanks! |
The drip tank looks like a GoingSuperFast one. I think I paid $80 for mine. |
That system is one of mine.
The headers/exchangers are SSI, Y-pipe is custom, RarlyL8, Muffler is mine, RarlyL8, and exits the stock location, Waste gate is OEM Porsche, Dump pipe is mine, RarlyL8, Oil sump tank is Asian. |
| All times are GMT -8. The time now is 03:55 AM. |
